Question about Genelec 6010 2.1 Stereo Pak Monitor Studio Active
Fuse genelec 6010
Replace the fuse
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
I have the power 8030 that I bought in London. I've been using them with my step up & down transformers. I moved to another studio and a kept the same configuration but now the wont power up using...
Compare the power inout voltage listed on the BACK of the speaker and compare that to your current power supply. You have not told us wheree you are or what your power there is... or the voltage listed on the back of your speakers. Giv us this info so we can better help you. These are expensive speakers to get things wrong...
Sep 12, 2011 | Genelec 8030.LSE Power Pak Active...
MY ALESIS DM5 WAS PLUGGED TO 220V AND AFTER A WHILE STOP WORKING ( IT IS FOR 110 V ) IS ANY FUSE I CAN REPLACE?
Hi pcruzx,
Sometimes replacing the fuse alone with exact voltage and ampere ratings will cure the problem(you're lucky) but not all. Sometimes further damaged gone to other parts most especially the voltage regulator transistor/IC (mounted in heat sink) and the opened the fusible resistor in line with the supply(B+).
First check the fuse, for sure it was already blown. If you've replaced the fuse and immediately blew again after powering on the unit, this was an indication of shorted parts near the AC line. Click this LINK for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Alesis Dm5 Drum Module 18 Bit
Does it have a fuse and if it does where is it located? Power blew and now it won't turn on.
Fuse is internal and unit needs to be repaired BEFORE replacing fuse as additional components may be damaged if fuse is replaced before repair is done.
Jan 15, 2011 | Line 6 Spider Iii 75 Guitar Combo...
How do I remove the rear panel to access the fuse? When I remove the six or seven screws, the panel still refuses to budge.
If the fuse blew, the problem causing that needs to be fixed BEFORE replacing the fuse. Replacing a fuse without fixing MAY damage further components that the fuse protected.
Often the Tolex covering makes removing panels difficult and one has to pry the panels out.
Dec 25, 2010 | Epiphone Amplifiers Valve Junior Hot Rod...
I need to replace the fuse for a used Marshall MG100HDFX that I bought. Where is the fuse located inside the head?
If the fuse is blown make sure the reason it blew is repaired before replacing the fuse. Start the amp up after replacing it with a 100 Watt light bulb in series with the hot side of the power into the unit. This will act as a current limiter to verify it is repaired and will not blow the fuse. When you open the unit the fuse will be obvious... Follow the hot side of the power cord, through the switch to the fuse.
Dec 08, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Power does not turn on for a marshall avt150h amp. most likely a blown fuse. got it a year ago and never had to get replace the fuse before. don't want to make a mistake. need instructions on fuse...
If the fuse blew for a reason, replacement MAY do further damage.
The way to test is to put a 150 watt light bulb in series with one of the power input wires and replace the fuse. The lamp will limit the current so further damage would not be done.
If lamp stays off and unit works, you are good to go. If lamp stays on, then service is required.
Aug 30, 2009 | Marshall Music
Have a hohner button accordian think it got bit of age to it how can i date it and find out what model it is it has no details on it wotsoever pls help
Try www.hohnerusa.com or www.accordion-search.com under new sites. Hohners toll free number is 800-446-6010. Good Luck.
May 15, 2009 | Hohner Corona II Diatonic Accordion
Genelec 6010 2.1 Stereo Pak Monitor Studio Active Logo
99 people viewed this question
Top Genelec Music Experts
Vito Vacirca Jr.
Are you a Genelec Music Expert? Answer questions, earn points and help others
