Question about Konka Televison & Video
Konka service mode
Adjustment video IF via service mode
I need konka tv model kp2107hsn service code
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 08, 2015 | Konka Televison & Video
Konka CRT TV model k 2039d service many
Type in the brand name only to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 11, 2015 | Konka Televison & Video
Iaccidendally push factory default on my remote now tv will not power on
Do a reset to this TV and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 30, 2014 | Konka KDL32AT23U 32 in. LCD Television
How i can acces to service mode on TV konka kl26gt611
You need to return to the initial set up procedure to disable SAP.
Jun 19, 2014 | Konka K2386U 23" TV
Konka model KP21EK312A service mode
Try find your konka tv service menu at http://tvservicemenu.blogspot.com/p/content.html
I hope you can get it for resolve your problem.
Mar 18, 2013 | Konka K2038U TV
Konka KLC 1508U
Most DVD players connect via the rear audio and video jacks--once correctly hooked up you switch the set to that input--not the cable fitting but the a/v jacks if set has them.
Apr 09, 2012 | Konka K1398U 13" TV
I don't know the model code
Hello
You are a technician and you whats to know the model service code I thinks, and posts this solution.
Use the Remote Commander (RM-Y183, RM-Y184) to perform the circuit adjustments in this section
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
Nov 30, 2010 | Sony KV-32XBR250 TV
Service mode tv konka K1418C
replece memori ic i need service konka tv service mode
Aug 28, 2010 | Konka K1398U 13" TV
Password manual service tv konka k1418c
bagaimana pasword menu servis konka model k1418c
Dec 16, 2009 | Konka K1398U 13" TV
How to access the video input channel for my Konka tv?
press menu twice and once + or - volume. and tv will enter in video imput mode.
Jan 27, 2009 | Konka K1398U 13" TV
Televison & Video Logo
18 people viewed this question
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
