Question about Karbonn K9
Charging show but battery not store - Karbonn K9
My battery is not charging, icon shows no movement at 23% since yesterday and it is not in use since charging
Need a little more info. To charge a battery and this goes for all batteries you must have a higher input voltage than what the batt. Is rated. For example a car battery is rated at twelve volts. To charge your battery the alternator applies about 13.4volts. So if you charger is under voltage it won't charge past the equal amount of charge in the battery. Take your charger to just about anyone with a volt meter and have the output voltage checked. Batteries Plus, auto parts store computer store, best buy geek squad in store should be able to help. Good luck, Bret
Sep 26, 2014 | Samsung Galaxy Note 10.1 N8000 Black...
Problem with lights on my tracker it drain's my battery i have a good altnator on it
If the lights drain the battery when the engine is running, then you have a bigger problem of the alternator not charging, not working. When the engine is running, the alternator supplies all the current to run the car's electrical systems, while also charging up the battery for the next start-up. If you know the alternator is good, then maybe a fuse or fusible link has blown, preventing the alternator from working. To check, put a voltmeter on the battery with engine running-it should show over 13.5 volts if the charging system is working. If the alternator is not putting out, the voltmeter will read same voltage on the battery as when the engine is not running. A fully charged battery should show "around" 12.6 volts. A discharged battery will show less than 12 volts. That should give you an idea of the range to look for on a voltmeter. I believe some parts stores will check the voltage for free. I know most stores will test the alternator and battery for free if brought into the store, but you need the voltage read while on the car and engine running. If the system is charging normally and the lights kill everything, you may have a short in the lighting system.
May 05, 2013 | 1994 Geo Tracker
Charging show but bettrey does not charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 11, 2013 | Cell Phones
AFTER HALF HOUR MY BATTRIES ON MY MOBILITY SCOOTER SHOW GREEN
Could be - I would take the scooter or battery to a car store and they will load check the battery - That is, they will cause the battery to do work, and measure the voltage.
Measuring volts while the battery is at rest will indicate full voltage. That would be a flawed test.
Dec 30, 2012 | Health & Beauty
Why my samsung laptop n150 plus is only charging 80% still i put on charge after 80%?it only show green light after 80% which means that laptop not going to charge after 80%...WHY?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Dec 04, 2012 | Samsung N150 Netbook
Max mq340 charging show but not save
As a general rule, re-chargeable battery can be recharged 300 times. This means that after one year or thereabouts, the battery will not hold the charge.
1 Look up battery replacement shops in your city. (Use Yellow pages or Google).
2 Take the old battery and the phone to the shop. Buy an equivalent new battery.
3 If there is no battery shop near you, try Amazon.com to find someone selling the battery (NOTE: Give brand name model name and battery part number in your request).
Nov 25, 2011 | Cars & Trucks
In lg rd 3000 voltage comes on battery tips but nighter charging shows nor store.
If there is voltage on the battery terminals then the battery must charge. Also if there is no indication of charge on the display then it can be relative problem of the board.
To confirm try to get hold of a similarr battery to swap and test so as to confirm if the battery is good and if the other battery shows a charging indication. If not the board can be faulty.
Jul 12, 2011 | Cell Phones
Battery shows fully charged but but turns on then off won't stay on
Time for a new battery. If it shows fully charged, and dies within minutes = old, tired battery.
Visit your local electronics store for proper, quality replacement.
Lete me know if this works for you
a
Sep 24, 2009 | Lands Phones
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Karbonn K9 Logo
12 people viewed this question
Top Karbonn Cell Phones Experts
akshay
Level 1 Expert
Tom Chichester
ray gallant
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
