Question about Saitek pro flight switch panel
How to solve saitek flight switch panel freezes
AMSATX
  • 27 Answers
SOURCE: Need for Flight Simulator Manual for Saitek ST290 Joystick.
you may get it at: www.flightgear.org
Posted on Jan 01, 2008
SOURCE: Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
Posted on Jan 18, 2010
rh10
  • 122 Answers
SOURCE: It turns on but it does not work in the saitek pro
You need to load the disk that came with the switch panel. Look in the directory where it installs and you will see a file in there that forces the program to load. Note: It is not the main exe file.
Posted on Jul 12, 2010
rh10
  • 122 Answers
SOURCE: saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
rh10
  • 122 Answers
SOURCE: Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Posted on Jul 16, 2010
How do I install saitek software on my Mac?
Isn't the panel support within the flight software itself? In which case it would be either in options or preferences. Saitek's software downloads are basically for controllers.
Feb 22, 2015 | Saitek Video Game Consoles & Games
Just purchased saitek yolk with throtle but its not working ,.tried calibration still does not work
I had a friend with exactly same issues, only he used a CH Flight Yoke system.
Calibration can be very tricky sometimes, and it has very often to do with how the configuration file has been set up.
You might have to rebuild your configuration file for your Flight Simulator before it will work properly.
However here is some hints for calibration fix from Saiteks UK support.
Maybe this can solve your problem, understanding how to make a valid configuration file for Flight Simulator.
http://www.saitek.com/uk/supp/yokefsx3.html
Good luck
Aug 24, 2011 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke Suddenly Stops working.... Usually when i switch on my pc, the yoke will also turn on as well by looking at the green light at the timer screen on the yoke....but now when i on my...
Try basic troubleshooting first, try to remove and reconnect the ps/2 and usb of the saitek pro flight, also try to put it in different usb ports to see if maybe a usb port is not working, lastly when all else fails try to connect it in another computer and see if it works.
Jan 02, 2018 | Saitek Pro Flight Yoke System Flight...
When i installed REX for fsx, my pro flight multi panel sis not work anymore...what do i do???
Reload the driver disk and in the directory that it installs into there is an icon which forces the switch panel to start up. You only need to use this option once then it will continue to operate normally.
Jul 07, 2010 | Saitek Pro Flight Multi Panel (PC) Flight...
It turns on but it does not work in the saitek pro flight switch panel
Jun 27, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Jan 01, 2010 | Saitek Pro Flight Yoke System Flight...
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight switch panel Logo
77 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
