Question about Garden
Fuel line routing for Poulan PP335 Trimmer
The fuel lines have been changed an d now it will not start. There are two sizes of line comming out of the fuel tank. Where do they belong?
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Poulan sm132 fuel line routing
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Posted on Aug 27, 2009
  • 165 Answers
SOURCE: I have a Craftsman trimmer mod# 358795121. What size fuel lines.
Sears has ample parts for repair.
Posted on Feb 27, 2010
  • 61 Answers
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Posted on Apr 14, 2010
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
Trimmer dies
If the bulb is cracked or gummed up inside it maybe starving the trimmer for gas. You stated you rebuilt the carb I was just wondering did you adjust it after the rebuild also did you put the same size needle jet back into it. In addition, did you change the screen for the jet they get gummed up and the screen will fill with residue most times.
May 11, 2017 | Poulan Garden
Fuel line route for poulan ppb300 string trimmer
Hi Brad...
I hope this is what your looking for
Please take time to rate me
Thanks,
Bud
Feb 21, 2013 | Garden
Changed filter and fuel lines, poulan 31cc 250E. starts fine but dies when accelarated
My chainsaw was doing this.The carburetors on these small engines have a fuel inlet screen that clogs with tiny bits of debris.Remove the carb,and take the portion off that has the fuel line attached to it(if you're careful,you can reassemble it without needing a new gasket).The screen is about 5/16" in diameter.Spray some carb cleaner in there to clean the screen out.(this is mt best guess,because it sounds like a fuel starvation problem)
May 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Aug 27, 2009 | Garden
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Jul 21, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
