Question about HP Compaq 2025 (Carbon, Silver) 20.1" LCD Monitor
Rmy 2025 made in 2002 only will show me cannot display this video mode, change comp. display input to 1600x1200@60hz. the monitor wont display nothing but those words I cant change nothing
It is stuck how to make it change back to 1600x1200h@60hhz
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
It's made to work on 75Hz smoothly. Try to change a graphics card.
Posted on Apr 25, 2014
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 16, 2010
Ezrahite
  • 2632 Answers
SOURCE: Hi. I have an HP a6115uk
Welcome to Fixya. It seems that the issue is not caused by the monitor or the video cable. You can determine if this is caused by the motherboard by using the onboard display if the motherboard has any. If you want to use the onboard graphic just remove the video card and it will automatically use the onboard graphic. If this wont still be able to fix the issue the problem that you have is the motherboard itself.
If you have questions please let me know.Thanks
Posted on Jul 28, 2011
No display but the computer turns on.
could be an issue with the graphics controller or with the monitor. first, verify if the monitor is actually working. try it on another computer or video source. if it works, make sure that you have a working video cable and check to make sure the video input source (dvi, vga, rgb, hdmi.. etc) selected on your monitor is the correct one that you are using. if you have ruled out the monitor, video source and cables, you can then test if another monitor will work with the computer. if same thing happens, meaning nothing on display even the manufacturer or BIOS screen does not show up when you turn on the computer, it is most likely the video controller. you may either get the motherboard replaced or install an add-in video card if the integrated video controller only has one video connector.
Jul 17, 2013 | eMachines MS-7145 Motherboard 103777
When you are in "comp"
The "Deg" indicates degrees are the unit used for trigonometric calculations. You can use [MODE] [5] to switch to radians or [MODE] [6] for grade. [MODE] [4] switches back to degrees. This is independent of "Comp" mode.
Jan 16, 2011 | Casio FX-260 Calculator
My monitor says input not supported
Monitor says 'input not supported', means the computer is sending an incompatible display mode to your monitor. Please check the user’s manual for supported display mode or input and configure your computer to those settings. The recommended setting for LCD panel is 1024x768 resolution and you may need to change the refresh rate of the monitor to 60Hz.
In Safe Mode, fire uop regedit and ry going to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Class\Display and delete that whole key (yes, this bascially will remove your video drivers) then reboot, when you reboot windows should start up in standard VGA mode and prompt you for the video card drivers.
For more, refer to this forum;
http://www.pcguide.com/vb/showthread.php?t=24178
Regards,
Anirban Mazumdar
Jun 04, 2010 | Computers & Internet
Cannot Display This Video Mode!!!
Restart your computer Press F8 key it shows Startup option choose VGA mode and Select the resolution after getting your desktop
May 06, 2010 | Dell Inspiron 530 Desktop Computer
Nothing comes up..after connecting it to my laptop
Try using the menu on the monitor
to change the input mode (much like changing the input channel on a tv).
also make sure that your pc display settings are set correctly.
Mar 04, 2010 | HP L1940T 19" LCD Monitor
I have now have a "video mode not supported" message on my L705 Hyndai monitor screen which came up right after I tried to change the resolution on my windows xp display. I can't get the monitor to show...
First connect you're monitor on to another system if possible. This will only make sure you're monitor is still working ok.
You're system needs to be shut down. (Keep you're monitor connected to you're system).
Than start it up and press the F5 key on you're keyboard every 2 seconds. This will bring up a screen that looks just like the one below;
Choose Safe mode from the list. Once you are in windows safe mode open windows control panel than open the display icon. Change the settings to where they were before you made changes. Chances are you need to lower the refresh rate and the resolution. Than save and exit the display properties. Close control panel. Cross you're finger and re-start you're system. If this doesn't work you'll have no choice but to hook up a much better monitor to you're system so you can change the display settings.
Cheers'
Mike
Feb 08, 2010 | Computers & Internet
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
LG Monitor Unable to Correctly Detect VGA Input
the problem is not the monitor.To be able to correctly set a dual display mode you need to configure you video card to do so. This is accomplished in your video card's control panel. There are various modes:
Clone: it simply clone the screen you'll have the same output on both monitors.
Extend: this will extend your desktop and make it one big screen.
theres another mode to show video only on one screen while the other display regular desktop activities you'll have to experiment.
the procedures for doing this varies depending on you video card: ati, nvidia, or Intel.
May 08, 2009 | Computers & Internet
My P35 S-611 not show VGA video
Check the refresh rate of the LCD, may be too high. Try at 60hz first.
Set the display to 1024x768 or 800x600 then go higher... allowing it to revert back to previous mode if nothing shows.
(some/most CRT monitors cannot display widescreen format)
Set at 60hz using a CRT (you will see flicker on CRT) - then switch to LCD
Apr 18, 2008 | Toshiba Satellite P35-S611 Notebook
HP Compaq 2025 (Carbon, Silver) 20.1" LCD Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
