Question about Honeywell T4398B1029 T4398 Electric Heat Thermostat, w/ Thermom. & Pos Off Switch
A new honeywell t4398a thermostat is calibrated incorrectly
Can't recalibrate because I can't move the scale ring per written instructions
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I install new RTH7500D thermostat Honeywell, when
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: Honeywell CT500 Electronic Thermostat showing
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on Aug 13, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: My old thermostat has only
The green wire is used to turn on the blower if you want constant air circulation. For heat only, the red and yellow wire will work as long as they are connected to R and W terminals on heating unit (or TH and TW on some models).
Posted on Nov 20, 2010
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
New ct31a, wired per instructions will not work. Putting R+G+W together will start AC, but will not start heat. what am I doing wrong?
Make sure the batteries are in correct and also make sure it is perfectly level. If those are not the problems then you have a faulty unit.
Oct 04, 2014 | Honeywell Ct31a Heating & Cooling House...
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How u go about increasing thermostat when recalibrating
Hi there!
Using a precision screw driver, turn the thermostat calibration screw counter clockwise to increase the temperature cut-in of the thermostat, it is about 5 degrees celcius per 1/8 turn of the calibration screw.
Regards.
Jun 28, 2012 | Imperial IFS40 Deep Fryer
Need to know how to calibrate my honeywell RTH221
This thermostat is not field servicable,you cannot calibrate this thermostat.May want to consider moving it closer to return air of equipment, for more accurate sensing of building temperature. Why do you feel that it needs calibrated? Suggest setting another thermometer on top to verify its accuacy.
Nov 24, 2010 | Honeywell Heating & Cooling
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Honeywell T87F Thermostat
this calibration is called the heat anticipator, this is set by the amp draw pulled through the t-stat,if you look very close at the scale you will see the word longer with an arrow ,if you push the lever in the direction of the arrow the heat will run longer .This is a very old style t-stat and is most likely out of calibration on the temp reading for the room, think of this portion of the t-stat as a stand alone thermometer,it may read 70 when the room is 74
Dec 08, 2008 | Heating & Cooling
Honeywell T4398B1029 T4398 Electric Heat Thermostat, w/ Thermom. & Pos Off Switch Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
