Question about Porta Gaz 3-Way 48 Liter/51 Quart Portable Gas Refrigerator
Will not run on propane
It works on electric power but will not light on propane
Does it need propane to run the furnace or can it operate on electric alone. i have no owners manuel
Got here late...I am assuming this is for an RV. There are probably electric furnaces on some of the newer ones, however, an electric furnace would draw more power than most parks could handle, so the is answer is it probably needs to have propane. On your panel, or near your furnace, you will see a switch to tell the furnace to use propane or electric...if your furnace is capable of running on electricity.
Sep 30, 2015 | Cars & Trucks
Want to camp with our Lp gas
sorry but that is not possible without a generator.
Jan 13, 2018 | Electrical Supplies
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
Refrigerator won't start. have replaced control board
Relay need to change after that your refrigerator will ok
Jan 23, 2018 | Refrigerators
How do I fix the propane oven in a Dutchman travel trailer?
check for a electric solenoid for the fas to the oven or a simple tap for the oven
could be a safety requirement for gas ovens in vans
Sep 17, 2017 | RVs
Should I use an electrical or propane lantern for camping?
I suggest propane or gas because they are cheap to operate and you are given the option of dimming, which is something you can't do with most electric lanterns.
Jul 09, 2012 | Camping, Backpacking & Hiking
Camper electrical wiring and propane lines dont work
you need to find the propane lines and where ever you have a joint you need to put "snoop" on it. which is basicly soap and water sorry my spelling sucks. anyway you do this with the propane on and whereever you have bubbles you have troubles. you can even check your lines with it. Now yoiur electrical woes can be fixed by tracing your wiring and finding out where you have a short this is when two wires are either touching eachother both of these problems take time and they take some experience. If you mess this up you could blow yourself up. Let me know what you are going to do. I'm worried for you
Apr 30, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Dometic RM2652 will not run on electricity only Propane
sorry but have absolutley no experience with propane run refrigeration, in America never seen such a thing, please repost with another expert,
Dec 18, 2008 | Dometic NDR 1292 Refrigerator
Porta Gaz 3-Way 48 Liter/51 Quart Portable Gas Refrigerator Logo
61 people viewed this question
Top Porta Gaz Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Porta Gaz Kitchen Range Expert? Answer questions, earn points and help others
