Fault code 02 on braemar lcb550-b
Need to know 02 fault code
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: Whats is error code 02 on braemar spectrolink?
Owner Manuals
Posted on Jul 25, 2015
My stove is flashing F7 02 CODES With constant beeping.
First things first. Brand and Model number. Although most fault codes have are similar across major appliances it is necessary to find a correct solution.
Apr 06, 2016 | Kitchen Ranges
Braemar heater
IS AIR INTAKE BLOCKED BY WALLS, FURNITURE, OR DUST AND DEBRIS?
Jul 21, 2013 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
My 2001 passport check engine light was diagnoised by a local parts store as oxyge sensor, now i find out that there's more than one (1) How do i know which one to replace or do i just replace them all or...
No I can not give you the code number because I did not scan it for you. The Diagnostic Trouble Code will show ( example 02 Sensor Bank 1 sensor 2 ) for the sensor at fault, or something simaller for one of the other 02 sensors. Fore ( example 02 Sensor Bank 2 Sensor 2 ).The parts store that did the scan for you should have given you the particular fault code as well as its location. If you replace one 02 sensor, you should replace all of them. Good Luck and have a good XMASS.
Dec 17, 2010 | Honda Passport Cars & Trucks
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Nov 22, 2010 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
2001 pt cruiser codes po 605 and po 700
Diagnostic trouble code P0605 indicates internal Transmission Controller fault. Needs to be replaced
Jan 07, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
14 people viewed this question
k24674
