Question about Xerox Phaser 6180N Laser Printer
Error code 016-720
Trying to print a PDF File that I e-mailed
Error 1007: An error occured while running Ghostscript How do I print my file??
Looks like GhostScript is corrupted and needs to be re-installed. Go to http://www.ghostscript.com/download/gsdnld.html and choose the appropriate version of Windows. Reinstall it and this will re-align the missing files and links.
Apr 10, 2015 | Bullzip PDF Printer
How do I print PDF file attched to e mail on dell laptop
Your need to do this ONCE.
1. Download and install Adobe reader.
2. Save any PDF file on desktop.
3. Right button of the PDF file and under properties, OPEN with select Adobe reader.
Now you should be able to open and print PDF file attachments,
Aug 21, 2014 | Dell Computers & Internet
Cant email or print invoices error code -20
which versions you use
QuickBooks 2011 versions only
  1. Download and run the QuickBooks Print and PDF Repair Tool.
  2. Once the tool completes, try the .pdf file-related task that originally generated the error.
  3. If the error still occurs, please try rebooting your computer and then try again.
http://support.quickbooks.intuit.com/support/Articles/SLN40733
for more help step by step visit
QuickBooks Online Support
Jun 29, 2014 | Computers & Internet
I am trying to convert my drawing to pdf file so I can e-mail to someone wittthout the program. Can you help?
To get your drawings to .pdf format you will want to print to a .pdf printer. To create a virtual printer that can handle this, you will need to download and install a program. I, personally, use CutePDF Writer. You can pick up this program here:
http://www.cutepdf.com/download/CuteWriter.exe
Then, when you are in Punch, you can choose to print whatever you want. Just make sure to switch the print output to print on the .pdf writer. It will ask you where you want to save the file.
Aug 03, 2012 | Punch Home Design Architectural Series...
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
Windows 7 cannot print email. An error message comes up as follows Line 1507 Char 1 Error invalid argument Code 0 URL res/ieframe.dll/prieview.is
You didn't say what e-mail you are using but from the error message it looks like you are trying to print from within frames. Are you using the print button inside the email or the print in the browser window? Try using the print button inside the email program not "file, print" or a print button on the browser toolbar.
Jul 06, 2010 | Dell Computers & Internet
I can't print pdf files from the internet, I have to "save as"1st
Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
Dec 28, 2009 | Microsoft Office Home and Student 2007...
I am trying to print to adobe to convert to a pdf file. I am receiving an error stating Prodcut name: distiller Warning: Script-cannot be embedded beacuse of font file error. Error: undefined; offending...
You probably have Adobe reader which will allow you to read an Adobe document but not write a pdf file. For that you have to buy Adobe Acrobat. There are, however, free packages that will convert a file into pdf format. Try googling for "convert a file into pdf" or something similar.
Nov 24, 2008 | Computers & Internet
Xerox Phaser 6180N Laser Printer Logo
1,199 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
