Question about Grundig G4000A FM/AM Radio
AM reception The interior AM antenna in my Grundig G4000A is broken. FM and SW work fine. I need assitance in diagnosing and correcting the problem.
  • Grundig Master
  • 7,993 Answers
If the internal antenna is broken that means the ferrite bar is broken,that does imply that the wiring around it is cut. If the two parts are not removed, the antenna may still be able to perform correctly (just as two magnets put end to end). You can try to put it in the vicinity of another radio to see if there is any resonance effect.
Hope it helps.
Posted on Nov 09, 2009
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Feb 14, 2010 | Grundig Mini 300 AM/FM/SW Radio
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
Hi Will the grundig G4000A get radio stations from overseas specificlly from Poland
Yes it will if you know the frequencies and the broadcast times of the radio you want. During the night the best broadcast bands are the longer wavelengths.
49 m from 6390 kHz and up
41 m from 7600 kHz and up
31 m from 9200 kHz and up
25 m from 12121 kHz and up
During the day Use the shorter wavelengths 11m, 16m, 21/22 m
Unfold the whip antenna, or use the wire antenna if you have one.
Reception is affected by the electrical charge denisty of the ionosphere. It depends on the solar activity (sun spot flares and such activities).
You will hear Radio China international all over the spectrum, Deutch Welle, Radio Canada International, Radio Havana, and a plethora of Religious brodcasts. If like me you miss Radio Moscow, it is now called Goloss Rossya (The voice of Russia). Don't get upset, I was joking.
Good listening.
Nov 06, 2009 | Grundig G4000A FM/AM Radio
How can I get a manual for the Grundig G4000A?
Here is the link to eton corp for your manual
Hope it helps.
Sep 09, 2009 | Grundig G4000A FM/AM Radio
I have had the Grundig G400 AM FM LW MW SW FM STEREO PLL SYNTHESIZED DUAL CONVERSION I have no Manual and can,t install my batteries correctly I would like to purchase a Manual if it is possible to do so...
This link will take you to the Grundig/Eton site where you can download and print the complete manual for your radio:
Bill B.
San Antonio
Apr 24, 2009 | Grundig G4000A FM/AM Radio
Black Meatal thing
The thing you are describing is a ferrite rod. It is the aerial that is used for LW and MW reception. The telescopic aerial on top is used for FM.
Providing it is a clean break and you haven't lost any parts of the ferrite rod, just tape it back together. It shouldn't have too great an effect on the reception.
Hope this helps,
Mar 08, 2008 | Grundig G4000A FM/AM Radio
Once you turn the unit on, the battery indicator should disappear. Make sure the batteries are inserted correctly. With six AAs, I've put them in backwards on more than one occasion.
Hope this helps.
Mar 02, 2008 | Grundig G4000A FM/AM Radio
AM/SW no longer functioning - FM still works fine
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Sep 15, 2007 | Grundig G4000A FM/AM Radio
Grundig G4000A FM/AM Radio Logo
179 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
