Question about Ultra Computers & Internet
Fan have power but fan not working
Fan is not working
Compac fan wont work
Replace the fan. The system will overheat and shut down if the fan is not working. Most systems won't boot up it the fan is not working.
Remove the power cord, remove the case and see which fan is not working. On desktops there will be a fan in the power supply where the power cord plugs in and one that sits on the motherboard where the cpu and heat sink are located.
Get on ebay and order another fan based on your computers make and model.
http://www.ebay.com
May 04, 2012 | Computers & Internet
Heater fan does not turn on
check for power to heater fan. run a wire from battery to fan, then use a piece of wire to ground it. if the fan works but will not work from switch, check the fan resistor, if ok. make sure you are getting power to fan motor. use a 12 volt test light to check for power at the fan motorwith fan selecter on.. good-day !
Sep 28, 2011 | 1997 Jeep Grand Cherokee
My maytag evaporator fan not working
Need to verify that there is power going to the fan. If no power at the fan verify the door switch is good. If door switch is good and in the closed position you still do not have power at the fan you have a bad board. If you do have power at the fan but the fan is not working with the door switch in the closed position you need to replace your fan.
Aug 31, 2011 | Maytag MFD2560HES Bottom Freezer French...
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
Intermittent operation of interior fan - isuzu kb/trooper
fan speed resistor block blown if fan works only on full speed (because power goes directly to fan on full speed, not through resistor)
if fan doesnt work on full speed check for power at fan on full speed with test light if power there fan faulty
no power check switch bank assembly
Aug 06, 2009 | 1999 Isuzu Trooper
X1 projector's fans not working
if the fan is not moving but still receives voltage, just replace the fan. if you're sure the fan works but no voltage, hope you're good at soldering. you need to remove the main board and solder a jumper from the bad fan's power and ground to the working fan's power and ground.
Jul 05, 2009 | InFocus X1 Multimedia Projector
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
Power Supply fan is not working in ThinkCentre M50 8189 D6G
Thanks for asking ...simply check the power supply fan....remove the Power supply(SMPS) from your system 1st....then remove the fan in it....try to rotate it by hands.....if it is not rotating smothly then it needs lubrication & your power supply unit needs cleaning.....if it is working fine then check the fan power section in Power supply...
regards
Mar 14, 2009 | IBM ThinkCentre M50 PC Desktop
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Lights and wall switch will not work
If the wall switch will not work at all, but the fan still works this tells me the power is not being sent to the switch and back to the fan. If it is a single switch and the power starts at the fan there should be a black and white wire on the switch. (pull switch out of the wall to check...turn power off first!!) If so they did a switch loop and the power wire should be connected to the white wire up in the fan box and the power (black) wire connected to your fan lights and fan motor. You will also see your power feed cable consisting of a black and white wire. Black is your power and white is your neutral. That white wire will be connected to the neutral wires of your fan lights and motor. (Note: your fan will have to disassembled and taken down to diagnose this). Good Luck!!
Jul 15, 2008 | Minka Aire F812-IO Lineage? Fan
Computers & Internet Logo
32 people viewed this question
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
CheckitRight
CheckitRight
Alan Hohenbrink
Alan Hohenbrink
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
