Question about Gateway M-7315U Notebook
How to lgh up key board
How to light up keyboard
My lights went out on my keyboard and wont come back on
What kind of Keyboard is that a gaming keyboard with all keys illuminated, if so to activate lighting, press the Backlight toggle key in the upper right corner of your Pro Gaming Keyboard.
if its a normal keyboard then your key board connectivity, check it firmly connected or any wire damages
Aug 20, 2017 | Computers & Internet
Key board light not working
Please specify the Make & Model of the Laptop. But, in general, there will be Function (Fn) Key or a different key combination that you need to press in order to turn the keyboard light on (if your laptop is equipped with keyboard lighting...).
Mar 30, 2014 | Computers & Internet
My key board with Dell Latitude laptop key board is not working. I purchased MK 250 wireless key board and conneted to TV for display The functional key for selecting the monitor is not there on the new...
The keyboard has a feature (and associated button) called F-Lock. By default, when the computer boots, F-Lock is turned on. In the F-Lock mode, rather than sending the standard key commands for the function keys, the keyboard sends special alternate commands (like print for F7 and save for F8) that are configured in the iTouch program. In order to force the keyboard to send the standard function key commands, you must TURN OFF F-Lock by pressing the F-Lock button! Oh, and by the way, there are no indicator lights on the keyboard, and the F-Lock button is an always up momentary button - just like the keys on the keyboard, so there is no way to tell what state it is in, other than by pressing it and then pressing an F key to see what happens!
This should solve your problem. Just turn off the F-Lock Mode.
Hope this helps if it does please leave a comment or a vote.
Thanks JHH
Dec 04, 2010 | HP DC170B Keyboard
None of the keys respond
Hi
It seems that the connection of the keyboard is disturbed.
Check the TOP Lights which are on the key board. If the num lock is working then it shows key board is fine with the connection or check the connector
Tx.
Feb 19, 2010 | Acer NSK8458AN Keyboard
When my keboard was connected to the system unit there was light on the keyboard but all the key are nt responding
Turn you computer off. Check to see if the keyboard is plugged in all the way. Now turn the system on.
Do the lights on the keyboard flash when the system turns on?
Can you push the caps lock key and get the caps lock light to turn on?
Can you push the numlock key and get the numlock light to turn on?
No? Well I would then try another keyboard. It's quite possible yours is broken.
Sep 24, 2009 | Dell OptiPlex GX260 PC Desktop
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
My check engine light is on and I every once in awhile my bat lgh
Is the light flashing on and of repeatedly ? If so that is a cadiliact damgaging misfire you. I would suggest a tune up if you have not done so already or lately
Mar 23, 2009 | 1997 Acura CL
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
Key board turning off
what model do you have?
Nov 16, 2007 | Compaq Keyboard
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Gateway M-7315U Notebook Logo
13 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
