Question about Intersource Enterprises Co Ltd Adventurer Six-Speed Folding Bike
Broken chain guard on 6 speed Adventurer folding bike
I need a replacement chain guard for a 6 speed Adventurer folding bike (both sides and 5 screws).
  • Don hunt
    Don hunt Apr 22, 2014
    Also have same issue.
Can I get a new shifting lever for my Adventurer Folding Bike made in 2011
Yes, you should be able to get a new shift lever. The lever is not specific to your bicycle, just needs to be compatible with the derailleur(s). A bike shop can help you select the correct one.
Oct 22, 2017 | Cycling
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Where can I find a manual for a Falcon adventurer bike? I haven't ridden it for a few years and can't remember how to work the gears
It means its an 18 speed bike. The shifting is easy. Start with the left side, begin riding, keep pedaling, don't stop pedaling in ther middle of a shift, it will throw the chain. As you ride, twist the shift grip, up and back. Still pedaling? Now after you have tried that one, try the other side, its the rear with 6 gears. Up and back, keep pedaling. After you have tried each individually, try them together. And now you're shifting. Looking good
. KEEP Pedaling
Sep 21, 2014 | Cycling
How to repair a broken chain on multi speed bicycle
to fix a broken chain you need a chain breaker tool to push the pins out of the links. Park makes a great one (Park CT-5, probably get it off of Amazon) for about $15. You can use the tool to remove the broken link(s), once removed, line up the good ends with the tool and push the pin back through. The link will be stiff, so you need to flex the chain laterally with your hands to loosen it up where you joined it together. DO NOT use a "master link" to join the chain together from a "single speed" bike, these will get jammed in the derailleur and cause more damage, and they are usually to thick for a multi-speed bike. Check out a repair manual or YouTube for details.
Jun 20, 2014 | Huffy Cycling
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
My son has a burner 20 and the plastic guard that covers the chain has broken off, looking for replacement
you dont need the guard and depending on the bike you can check on dans comp .com or ebay is your best bet
Sep 17, 2009 | Cycling
Intersource Enterprises Co Ltd Adventurer Six-Speed Folding Bike Logo
67 people viewed this question
Top Intersource Enterprises Co Ltd Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Intersource Enterprises Co Ltd Cycling Expert? Answer questions, earn points and help others
