Question about Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer on off switch
Changing timer switch to manual on/off switch
I've had my Mazzer Mini for about 3 years. I grind about 1/2 lb per week. Today I went to grind and when I turned the timer switch nothing happened. Yes it is plugged in. I think it makes a popping...
1 check the supply wire to swich change if it is not ok 2 chek the swich change if it is not ok 3 if it is automatic check microswiches(one where ground coffee comes out and other below doser) clean from coffee upper swich and try. it block sometime from ground coffee 4 check the windings of electromotor give grinder for if it is not ok 5 check condensator change if it is not ok 6 try to spin the burrs by hand, check if they are not blocked. change bearings if it is not ok
if you need to change bearings you need advice how to open the motor.
Jan 05, 2011 | Mazzer Mini Burr Coffee Grinder
How do you change a mazzer mini from timer to manual
Once you have an on/off switch you will remove the bottom panel ans timer, you will see 4 wires, 2 brown and 2 blue. Just make sure you connect brown to brown and blue to blue on the correct terminals. Use your Ohmsmeter to correctly match terminals.
Sep 02, 2010 | Mazzer Grinder-doser MINI
Grind is like powder
There are 3 springs in the holes around the top neck of the machine, the top part which sits under the collar adjustment knob.
Mar 28, 2010 | Mazzer Grinder-doser MINI
Mini mazzer grind doesnt adjust
Can the silver collar turn? If yes then adjust, clean out all the grounds then grind for 3 secs, clean grounds then 10 secs(that will give you about 12-16 grams for a test shot). The 3 secs grind and clean is for the coffee that is already ground with the previous setting, there is still a small amount between the burrs and the chute.
Jun 28, 2009 | Mazzer Mini Burr Coffee Grinder with Timer...
The mazzer mini doesn't grind
Either the burrs are set too fine, or the gate for the bean hopper is closed.
Mar 14, 2009 | Mazzer Mini Burr Coffee Grinder with Timer...
Mazzer Super Jolly Manual
Check out this link for the Super Jolly manual:
http://www.wholelattelove.com/manuals/Mazzer/Super%20Jolly%20Product%20Manual.pdf
Feb 19, 2008 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer Coffee-grinder SUPER JOLLY Electric Logo
Top Mazzer Coffee Makers & Espresso Machines Experts
Brett Duxbury
Brett Duxbury
Bill Boyd
Mister Danger
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
