Wasmo video qarxis wasma ah
How to chang fog light holden astra ah ?
unscrew lens. take out bulb?
some lens dont, come off, and at Rear is a socket you un twist.
all cars all lamps like this. just looking a moment this comes to mind.
ah no screws. whats behind here, ah,, ,there.
Jun 16, 2014 | Holden Astra Cars & Trucks
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Can you add 2-12 v 18 ah batteries in parallel to back up 2-12 volts 32 ah batteries?
hi, you mustn't do that ,,, you can get excessive current flow and that will damage the battery in question
Regards
Rob
www.gewizrepairs.co.uk
Mar 01, 2014 | Electric Mobility Health & Beauty
12 volt battery
Hi, the answer is yes but you have to make sure the 5 AH is the same size physically as the 4.6 AH one. Also make sure the voltage is the same.
Jan 29, 2014 | Motorcycles
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
May 11, 2013 | Sharp Heating & Cooling
Ford 6000 cd visteon kw2000 6s61-18c815-ah V050350 keycode?
FORD 6000 CD SINGLE CD-KW2000 FDB2006 6S61-18C815-AH
Serial N V047160 . Name Dido
Feb 09, 2013 | Visteon Car Audio & Video
My acer netbook has a low video memory (8mb) and I can not increase in the bios, it is locked, Can anybody help me with this problem?
Ah, don't worry, my Aspire One has very little video memory aswell... my solution was buying a minipci video card.
128mb- works like a charm :)
google such device for retail information.
Sep 15, 2009 | Acer Aspire One AOA150-1784 Netbook
Computers & Internet Logo
David Payne
David Payne
