Question about Thermos Genuine Brand 16 ounce Stainless Steel Leak-Proof Travel Tumbler
The plastic insert in the top popped out of my 16oz. Thermos bottle.
It is the plastic piece that has a piece of rubber that snaps onto it.
2 Suggested Answers
  • 4736 Answers
SOURCE: i lost the regulator for
The regulator can be found at th e following link. The rubber piece is no longer available.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=15118&modelsID=126646&typeName=gas%20grill
Posted on Jul 13, 2011
It is possible to take apart a Whirlpool wine cooler door to replace the tempered thermal glass unit inside. Door is stainless steel with plastic insert on inside with gasket in the plastic insert. I
It is likely a double glassed unit, You can try and slide a thin bladed knife like the snap blades between the glass and the rubber and cut it away., You may be better to take it to a glass company that make DGU (double glazed unit) and they will be able to produce another piece o glass for it and put it back through the machine to make it a new unit.
Aug 28, 2014 | Whirlpool 38-Bottle Wine Cooler
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
Washer will not begin spin cycle
Hello,It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor.
Thanks
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin in any cycle but motor runs and pumps out.So lid switch is good? what shifts to spin a sol?
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor. You should be good to go.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Jan 11, 2010 | Whirlpool LTE6234D Top Load Stacked...
WONT WASH OR SPIN
Jan 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is about 8 years old & no problems till now. It filled and then started the agitation cycle and we heard a loud noise. Agitator not working, still makes horrible growling sound, drum still full...
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer doesn't spin or agitate
if the motor is spinning but the drum is not then its probably a belt or the transmission. if there is no motor noise it is more than likely the lid safety switch.
Dec 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
KEY THAT POPPED OFF
Make sure you have all the pieces of your key, including the small rubber piece that is usually on the keyboard, a small plastic piece and the key. Just make sure the piece is on, or just rest it on there after the next step.
Replace the plastic piece next. There is generally a small notch hanging out of the keyboard, place the corresponding hole in the piece underneath, then put it so that it covers the spot, the apply pressure and secure the remaining points.
After this, generally it is just a matter of snapping on the key, try to use a back to front motion when doing this to ensure it is secure. And, That should be it
If your key and the plastic piece are still together, essentially just use the third step, taking care to make sure it catches the notch.
Apr 06, 2009 | Dell Vostro 1500 Notebook
Kodak EasyShare Z612 Digital Eye piece
you have to take off the back plastic part of the camera carefully. I snapped it off carefully. Then you take off 2 black screws at the eye piece and insert the rubber. screw back together. snap plastic back on and screw in all the screws. have fun!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Thermos Genuine Brand 16 ounce Stainless Steel Leak-Proof Travel Tumbler Logo
488 people viewed this question
Top Thermos Home Experts
john h
Tom Chichester
Are you a Thermos Home Expert? Answer questions, earn points and help others
