Question about Roland VersaCAMM SP-540V
Verticle streaks I am printing 2 images. The one on the right side is fine but the same image on the left side has a magenta and a yellow streak going down the middle. What is that caused from? Please help!
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Apr 28, 2008 | Office Equipment & Supplies
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Lens Shows Out of Focus and Streaked Views
Nikon has a free recall on this. Go here: http://www.imaging-resource.com/badccds.html
Jul 08, 2006 | Nikon Coolpix 5700 Digital Camera
Roland VersaCAMM SP-540V Logo
26 people viewed this question
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Ravi
Chas Peters
Level 1 Expert
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
