Question about Walkera QR X350 Quadcopter BNF WALQRX350
Motors stop as throttle increases
Props stop before lift off
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Spin the props over by hand and see if any are dragging; if they are then that is the problem. Those speed controllers have a safety that stops them if there is resistance on the motor. One other thing it could be is your battery could be bad or not getting charged properly. Good luck.
Posted on Apr 05, 2014
Mercury 150 hp 2 stroke 2003 everything runs fine with idle throttle lever engaged but when you put motor into gear i stalls idle to slow how do you adjust it thanks
If someone changed props this can cause this problem. You need to be careful that any adjustment is made for throttle rod and not for carbs if not an injected engine. You do not want to fool around with air mixture. Some throttle cables use threaded linkage and length of rod is adjustment for rpm. Others use a stop screw or hex head to move the throttle lever away from the housings.
Apr 01, 2017 | Mercury Cars & Trucks
Tip
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
on Mar 16, 2011 | Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Where do i put the blades
    Its actually quite simple if you follow what I say. I am assuming that you removed them all and forget where they go.
    Usually, the two front rotors are a lighter colour, but opposite in pitch/rotation.
    What you must not forget is that all propellers must only try and pull upwards, that is blow air downwards.
    Then power the model without props and make each motor run (or all 4 together without any props. Note on a piece of paper the direction of rotation of each motor, mark front at the right place on the paper!
    Now look at each light coloured props, they should be opposite handed, imagine them turning in the direction of each front motor and pulling upwards. Put each one on the front motors as you think they should go.
    Switch on the copter, link the remote control, hold model firmly and make motors turn. Both motors should blow air downwards. If the opposite, swap them. Test again.
    Do the same for the rear motors.
    Do not forget that the colours are only to help with finding the front when flying, otherwise the pair of propellers at the front are the same as the ones at the back....so you can place the coloured pair you like for the front or the back, where you wish to have them.
    I hope this helps.
    By the way, the motors are often sold as four, each one with its own position, but in fact the motors are either turning CW or CCW.
    I have not ever tried reversing polarity, as this might possibly damage a motor if they are brushless....so don't try that unless you KNOW its OK.....
    Someone here may already know for certain....
    regards
    Andy
    Jul 18, 2014 | Protocol Manta 4-Channel Radio-Controlled...
    I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
    I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
    Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
    Where is the idle control valve on the 1999 Cadillac De Ville and is it the same thing as the idler motor?
    The IAC or idle air control valve is mounted in the throttle body and uses an air passage that opens or closes to increase idle speed where as an idle motor usually pushes against the throttle plate to increase idle speed most idle motors (stepper motors) where phased out and was never used on port fuel injected engines chances are you have an IAC valve
    Dec 11, 2012 | 1999 Cadillac DeVille
    Ryobi chain saw wont throttle down to idle
    check the choke linkage it props the throttle open
    May 20, 2012 | Ryobi Garden
    Silver bullet helicopter wont stop spinning counterclockwise
    i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
    Feb 13, 2010 | Shuttle 9094 Emax Remote Control...
    Ford escort 1989 increases its speed without stepping on the gas
    First guess is that a motor mount is broken and lifts one side of the motor just enough to pull on the throttle cable.
    Second guess is that the cable return spring is broken or missing. It pulls the injector throttle body lever closed when the gas peddle is released.
    Oct 15, 2009 | 2000 Ford Focus
    Walkera QR X350 Quadcopter BNF WALQRX350 Logo
    120 people viewed this question
    Top Walkera Toys Experts
    Michael Galve
    Michael Galve
    jasen linko
    jasen linko
    Are you a Walkera Toy Expert? Answer questions, earn points and help others
