Question about LG DLGX3471V 27" Front-Load Gas Dryer
Brand new Machine starts with loud noise and than shuts off. Its the second machine
I bought the LG DLGX3471V gas dryer. I connected the gas line, connected the plug to the electricity. The machine starts with a loud noise, the drum turns very slowly for less than a minute and than shuts off. This is the second machine with the same issue. Is it me missing something from the installation or is it the machine! Thanks
  • 496 Answers
SOURCE: LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: LG dryer was making a squealing noise, then
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfhjdg
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: did you resolve your dryer / noise?
heatman101
7687t
Posted on Sep 30, 2010
Jahn27
  • 1554 Answers
SOURCE: LG Front Load Dryer -
The drum rollers need to be replaced at once. Disconnect power then remove the three screws attaching the top panel bracket to the rear of the machine. Push the top panel backward then lift to remove.
Remove the two screws attaching the control panel frame to the cabinet. Disconnect the connectors then pull the control panel assembly upward and then forward to remove.
Open the door and remove the two screws from the bottom of the door opening. Remove the four screws attaching the front panel from the cabinet. Disconnect the harness of door switch then remove the front panel.
Disconnect the door lamp and electrode sensor connector. Remove the four screws attaching the front bulkhead to the cabinet then remove.
Remove the drum and the rear bulkhead for complete access of the drum rollers. Reassemble the dryer in reverse order of the disassembly steps.
Please make you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 22, 2010
  • 273 Answers
SOURCE: Our LG DLE0442W electric dryer is now flashing the
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Posted on Feb 21, 2011
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
I would like to know how to maintain a gas dryer that has been sitting unused for over 3 years, I want to make sure it will be safe to use. Anything I should do before I connect it and start it up?
Providing that the machine was not stored in a wet location or out in the elements you should have no problem. If it were me I would first thoroughly clean the machine, then plug the machine in without the gas line hooked up,start the machine. Let the machine run for a few minutes and listen for the igniter to cycle and for any unusual noises. If everything sounds ok proceed with gas hookup.
Aug 01, 2013 | Kenmore 62602 Electric Dryer
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
The dial on my LG Dryer does not light up so I don't know what cycle it is on
The dial on the switch should pull straight up and off, giving you access to replace the lamp.
murf427
Aug 01, 2012 | LG DLGX3471V 27" Front-Load Gas Dryer
Lg dlg7188rm - My dryer is not getting hot. When I start a cycle the ignitor comes on (orange glow under dryer) and then gas comes on (blue glow). After about 30 seconds both shut off.
There are two or three sensors in the heat exchanger and another one or two in the fan housing. Check them all for continuity. One in the heat exchanger is resettable
Jul 22, 2017 | LG DLG7188 Gas Dryer
Dryer making loud screeching noise LG Trom DLG5988S
heatman101
Asker
Jan 03, 2011 | LG DLG5988 Gas Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
LG DLGX3471V 27" Front-Load Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
