Question about Whirlpool RBD305PD Electric Double Oven
No diplay or oven light - Whirlpool RBD305PD Electric Double Oven
  • 27 Answers
Control board is bad, contact sears to ix
Posted on Jun 14, 2009
I have a Baxter ov310e oven a customer asked me to check on. Of course while there had no issues at all. She said when they were using it earlier in the day the temp diplay started flashing. It was near...
SAFETY ALARM (STANDARD FEATURE, NO PARAMETER SETUP REQUIRED)If the temperature at the probe is in range of 570 to 600°F for 10 seconds, the unit will do the following:1. Shut off all features.2. Sound an alarm.3. Flash the OVEN TEMP display (actual temperature is displayed).4. Display the letters 'SHdn' in the BAKE TIMER display.Disconnect the electrical power to the oven and follow lockout / tagout procedures.There may be multiple circuits. Be sure all circuits are disconnected.
Troubleshooting - Baxter OV310E Operation Manual [Page 29] https://www.manualslib.com/manual/1248539/Baxter-Ov310e.html?_e_pi_=7%2CPAGE_ID10%2C4341941345 -- shared by UC Mini
Jan 19, 2018 | Baxter Ovens
F1 on oven diplay
What brand of oven do you have? On GE and some Kenmore models, the F1 error is a problem with the touchpad or the ERC (electronic range control or clock). On some models, the two parts are sold as an assembly. On some Maytag ovens, it can be a problem with the oven temperature sensor.
If it is a keypad error, the test for which part has failed is straightforward, if they are sold as separate units. Unplug the oven and move it out to reach the back of the control panel. Unplug the ribbon connector for the touch pad from the clock. It's a flat wide (~1 1/2") wire. Make sure that the wire will not touch anything and cause a short. Plug the power cord for the range back in. If the F1 error recurs promptly, replace the ERC. If after 30+ minutes, the F1 error has not returned, replace the touchpad. If the touchpad and the ERC are sold as an assembly, you'll need to replace the entire unit.
For the oven temperature error, you'll need to check the continuity and resistance of the wiring across and around the sensor and back to the ERC. Check the wiring harness as well for any corrosion. Replace the sensor or the wiring depending on what you find.
I hope this helps. Please add a comment with the make and model of your oven for additional support and replacement part suggestions.
Jul 08, 2015 | Ovens
Feb798wcc-a lower oven diplay "lock" and will not
Hello & Welcome to FixYa
First, unplug it for 30 minutes and if the problem returns then it means that the door lock assembly is bad & needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 25, 2011 | Frigidaire Ovens
I have about a 14 year old Whirpool Double Oven model RBD275PDB1. The other day it was working and then in the middle of cooking something it just went off-nothing working. I checked the fuse and it was...
If there is no power at all then I would check where the house power comes into the oven.Be sure to turn off the power before looking in the conection box.Hopefully you will not have to pull out the oven to find the box.
Jun 13, 2011 | Whirlpool RBD275PD Electric Double Oven
F3 diplay after changing temperature sensor I had
Sorry to read about your problem, I hope this helps you out.
you may have a defective sensor card, plus i would recheck the wire nuts... check for around 1000 to 11000 ohms resistance.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
I have a kenmore elite electric range and it is diplaying a F7 code what can I do to fix it.
f7 error code usually means stuck function switch on control panel. Need to check each button or switch to see which one is stuck
Mar 19, 2010 | Kenmore Ovens
Not functioning
clock can be bypassed. you will have to get at the clock connections though.
you will see a recangular box on the clock pcb which is in fact a relay. next to it are two connections with fairly heavy wiregoing to them. join these together and the clock is then bypassed. you can get female to 2-male connectors which are very convenient for doing this. i must have bypassed hundreds of clocks over time
Jun 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Whirlpool RBD305PD Electric Double Oven Logo
178 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
