Question about Tanaka Weed Line Hedge Trimmer Sf Ht Attachment Tool Hedge Trimmer Adjustable
Tanaka 5500 carb adjustment
Weed eater carb adjustment
Why will My weed eater only run with the choke fully on and cant give throttle?
It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Petrol weed eater will not start. Alomost starts
Hi Mark, I own a shop, we will not work on ryobi, have you gotten 2 seasons out of it? If so thats probably as good as it gets. But you can check carb settings. In the USA they come with limiters on the adjustment screws, not too much you can do(break them off) back your adjustments counter clockwise 1half turn.
Dec 20, 2010 | Ryobi Three Trimmer Combo
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need tool to adjust carb on a ppb 100 polan weed eater
1 1/4 turns out. Then let it warm up and adjust 1/8 turn lean, which is in, to make it run best. But that is only right if you just rebuilt it and everything inside clean and wrkn right. May have to adj in less?
May 11, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Mar 30, 2009 | Garden
Tanaka Weed Line Hedge Trimmer Sf Ht Attachment Tool Hedge Trimmer Adjustable Logo
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
