Question about Fantech Dryer Booster Fan Fantech DBF110 Kit
Blew out lint in fantech dbf110 and reconnected the line the fan will not turn on
After blowing lint out of fan the motor will not come on
2 Suggested Answers
  • 63 Answers
SOURCE: fantech exhaust fan won't shut off.
Faulty switch (replace it) or Loose switch (wrap the body with electric tape)
Posted on Sep 12, 2009
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
KEEPS BLOWING THERMOSTATS
usually the thermostats blow when the dryer runs to hot so you don't have a fire,most likely the dryer needs to be cleaned out and the vent line has to be cleaned,you didn't send the model number or brand name so do this,unplug the dryer,you have to remove the filter and clean the duct that the filter slides into,most of the time you have to take the dryer apart to do this right.then blow out and vac all the lint in the cabinet where the motor is.now go outside,make sure the vent is open,if there's a cage on it or screen remove it,all it does is block the lint and then the air can't blow through building up lint in the line,i take the vent line off the back of the dryer,stick a leaf blower in it and blow the line out,i've had people say the line was clear,i go there,blow out the line and on two occasions i blew out birds nest.when the dryer is clean,change out the thermostats that are bad and you'll be fine
Mar 10, 2011 | Dryers
I replaced a relay for the cooling fan, when the fan came back on it blew the relay. Does that mean the fan motor is bad?
Do you mean the fan fuse? I ask because relay's don't just "blow" . If it is in fact the fuse that is blowing... with the car off and fan off try turning the blade. If it's very difficult to turn, then yes your problem is in the fan motor. If it's not difficult to turn it could still have a problem and be pulling too many amps. You can hook up an ammeter in line to the fan and see how much amps the fan is taking. If it's close to the amperage rating on the fuse it is likely the cause of the fuse blowing.
Dec 05, 2009 | 2000 Chevrolet Impala
A load was running and then my dryer just turned
SOUNDS LIKE YOU BLEW A FUSE IN YOUR DRYER. THAT WILL HAPPEN WHEN YOU HAVE A VENTALATION PROBLEM. THE FUSE SHOULD BE BEHIND THE BACK COVER-AT THE BOTTOM--TWO WIRES PLUG INTO IT AND IT IS PROBABLY WHITE.
Nov 03, 2009 | Whirlpool GEW9250 Electric Dryer
Fantech exhaust fan won't shut off.
Sep 12, 2009 | Fantech Dryers
Remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Dec 16, 2008 | Reddy Heater-30-55,000 BTU Variable
Fan blades or motor in Nucor over the stove hood
it is hard to get the fan off. but if you are carfull you can do it. but any large home improvment store can help with a new fan.
May 03, 2008 | Kitchen Ranges
Electric dryer lint
You are purchasing new dryers when the problem is your vent line. The fact that your old dryer is now working in a different home, and your new dryer still has the same problem as the old dryer, leads me to suggest that you reroute your vent line some how. Your dryer vent line is really too long. The fact that you've added two 90 degree bends also leads to the issue of lint build up problems by creating added resistnace. It's a simple theory of operation when it comes to dryers. The SHORTER and STRAIGHTER the vent line the BETTER. All vent hoses create some resistance to air flow. It is typical in longer runs that the lines build up and accumulation of fine lint over a period time which adds weight to the line. This can cause the line to sag and restrict lint even more. Any bend in the line (especially 90 degree bends) also create points of resistance where lint tends to build up. This eventually leads to clogs, longer dry times, dryer overheating and eventual failure of the appliance. Purchasing higher end models does not necessarily equate to better performance. Many of your low end Kenmore, Maytag and Whirlpool models are great dryers and last years with proper care and maintenance. Even though you don't have this configuration, I thought I might add that it's also a bad idea to have vent lines that run vertical (such as in an attic). Dryer exhaust has moisture content from the clothes. When the lint mixes with this moisture it becomes more dense. If you have a vent line that runs vertical, this line will eventually settle at the lowest point of the vent line (which is usually right where it enters the wall). Reroute your vent line and shorten it and I bet your problems will go away. It's cheaper to spend the money on some semi-rigid vent hose than several hundreds on another appliance that will probably give you the same results. I hope this helps you,
Jan 16, 2008 | Dryers
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Fantech Dryer Booster Fan Fantech DBF110 Kit Logo
Top Fantech Washing Machines Experts
Are you a Fantech Washing Machine Expert? Answer questions, earn points and help others
