Question about Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver
Location of serial number for sole e55
Sole e55 elliptical serial number location
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
Aug 30, 2014 | Sole Fitness Sole E55 Elliptical
Display Problem
Yes, you do need to either replace the entire console (4 screws) or the display board.
Dec 16, 2013 | Sole Fitness Sole E55 Elliptical
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
Apr 04, 2013 | Sole Fitness Sole E55 Elliptical
Where can I find the serial number on a Sole E25 elliptical trainer?
on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. pry it up with a screwdriver, it should unsnap, and will reveal the mythical red serial number.
Feb 08, 2011 | Health & Beauty
Sole E55 display is wrong
Unfortunately you will have to replace upper console it has an internal sum problem in the chip nothing mare can be done.
May 14, 2010 | Exercise & Fitness
Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver Logo
64 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
