Question about LG WM3987HW Front Load Washer / Dryer
LG WM3987HW does not start (no power)
Originally showed UL code, then went dead and now won't even start.
2 Suggested Answers
  • 4134 Answers
SOURCE: I have a LG plasma TV. The picture won't come on but the sound does. It's a 52" model# 50pc50-ul. Production code 50pc50-ul AusYLSJR. Power 100-240v~50/60 Hz 4.5. Pcc ID: BEH50Pc5DUL.
This TV is 2007-2008 vintage. If you've had it this long without losing the picture, you've been lucky. Plasma and LCD panels are excited electrically to generate images, but they do not produce adequate light on their own to make the image visible. Thus, manufacturers install a backlight circuit which treats the LCD/Plasma panel much like a slide in a slide projector. When this backlight fails, you lose the visible image, even though the image is still on the panel. Older sets such as yours used florescent bulbs to light the screen. The use high-voltage inverters (ballast) that are the usual failure culprits. Newer sets use LED lighting. These use far less current and tend to last longer, but the jury is still out on their longevity as they are fairly new to the market. Inverters can be replaced, but be advised, as the florescent bulb ages, its color will change and it will affect image quality. So you may want to consider upgrading to a newer set.
Posted on Nov 02, 2015
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
My girlfriends LG wm3987hw just lost its power. the outlet is fine. there is absolutely no power getting to the machine. No lights, nothing. Anyone else have or had this problem? Fixable or DOA?
the wm3987hw has an internal fuse located on the "power connection noise filter", It's a transformer or something which cleans up the wall-supplied voltage a bit before it touches the expensive electronics.
You might just be able to replace just the fuse, otherwise the whole unit is part#6201EC1006T, about $50.
take the top off the unit (two philips screws on the top back) you will find the power noise filter on the top inside right wall of the unit. it's not terribly involved to do this fix yourself. 20minute job tops.
Jul 27, 2015 | LG WM3987HW Front Load Washer / Dryer
Wm3987hw squeaks
Probably a loose or worn belt.
May 03, 2014 | LG WM3987HW Front Load Washer / Dryer
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
My phone went dead, It wont even turn on. Even when it is plugged into the charger
It could be the power on switch that may be bad. You cant throw away a phone like this. So, show it to the LG Service Center and let them decide as we cant replace the switch (if need be) without special tools that most of us do not have.
Aug 19, 2010 | LG enV Touch VX11000 Cell Phone
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LG WM3987HW Front Load Washer / Dryer Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
