Augen gentouch78 won't come off sleep mode
Stuck in sleep mode
5 Suggested Answers
  • 162 Answers
SOURCE: my averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Posted on Jun 03, 2010
dlwcowan
SOURCE: My USB Robot owl won't
Mine did the same thing there is a green wire and copper coil wire that came un-soldered in the head. it uses a magnet and magnetic coils to move the eyes. you will need to get someone to resolder it for you... of do it yourself.
Posted on Jun 05, 2011
bronk50
  • 27725 Answers
SOURCE: Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Posted on Nov 26, 2012
  • 1631 Answers
SOURCE: I have a density riverspas hot tub and it is stuck
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Posted on Dec 18, 2012
Acer aspire z3750
hold down the ctr-alt-delete button same time should bring it out sleep mode and allow you to restart the pc. Once back on desktop go to power settings and turn sleep mode off.
Apr 20, 2014 | Acer Aspire Computers & Internet
M305d-s4829 stuck in sleep mode
go to power potion and disable sleep mode
Jan 30, 2013 | Toshiba Satellite Computers & Internet
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
Dec 03, 2012 | Pool & Spa
Acer3000 yellow light solid and will not power on Help! Is this motherboard issues?
It's very possible you have motherboard issues. Hardware failures will often resemble the machine being stuck in "sleep mode". You can try a power "reset" in case it is stuck in sleep mode. Press and hold the power button for 30 seconds. If successful, the machine will boot (probably in safe mode) and you should be able to re-configure your power settings to disable sleep mode. If this doesn't work, you most likely have hardware issues and the motherboard is most likely the culprit.
Aug 20, 2011 | Acer Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
My USB Robot owl won't blink. I know there are 3 different modes but it seems stuck in the sleep mode. Any fixes?
May 05, 2011 | RTO USB Robot Owl - White
Monitor is in sleep mode and I here a beep periodically
Try change the keyboard, if the pc does not detect the keyboard or a key from the key board is stuck which gives something like tic tic sound. On the other hand the display from monitor "sleeping mode" indicates the VGA cord is faulty or monitor is no compatible to the PC's video card.
Nov 26, 2008 | HP Computers & Internet
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
