Question about Plextor PX-708A DVD±RW Burner
Having problems How come my px 708a cantread a bar code? Plus now i can't burn from this source to another driver.
  • 2,427 Answers
It might be damaged.
actually i think it is and maybe you can try replacing it. if you want to try a fix let me know
Posted on Dec 30, 2007
You can unlock Your ALCATEL OT-708A using unlock code. You can get the unlock code from any online site. For example you can get the unlock code from this is one of the trustworthy site providing accurate unlock code at very low cost. with step by step guidance on unlocking process.
May 11, 2012 | AT&T Cell Phones
After a re-installation of WinXP, my px-716a will no longer burn. Checking the drivers, I see they are all Microsoft drivers so I downloaded the latest Plextor drivers (v1.11) and supposedly updated them -...
hello, the dirver is not the issue, its the hardware itself. try to do this; control panel-administrativetool-imapi cd burning rom, and choose disable,.. Why? maybe the lens has not enough power...
Mar 09, 2010 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
Plextor px-708a will not recognize disks. Just removed a second DVD drive from the system and jumpered px-708a as MASTER. The system recognizes the drive; it just will not read.
as you've changed the configuration of the drive from slave to master you need to go into the bois and change the settings for the drive so that it reads the px as master cd drive
Feb 25, 2010 | Plextor PX-708A DVD±RW Burner
Go to and download the firmware update. If you have the 708A-UF model, make sure you install the firmware update using a USB cable. Using a firewire cable to do the update can cause a data corruption problem with the firmware update.
Feb 17, 2010 | Plextor PX-708A DVD±RW Burner
PX-708A Drive not working
This drive does not have power. First open the case and check power cable to make sure it is properly seated. If your power supply has additional power connections of that type, try swapping them (it is a 4 pin molex connector used for IDE hard drives and CD drives). You might want to use a multimeter to check the power output on those connectors.
If the power supply is providing sufficient power and properly seated, it could be the drive itself has failed. (The power is not getting past some part in the drive. I do not do CD drive disassembly so I don't know if there is a fuse or some ofher component that you should look for having been damaged.) With IDE DVD-R/W devices being available for $30 or less, it isn't worth the time to search. Replacing it with a new one is simple.
I hope this helps.
Jan 25, 2010 | Plextor PX-708A DVD±RW Burner
I get kicked off line whenever I open either one of my optical drives.
try updating the drivers.if you cant just uninstall them and reboot the computer.Windows will find new hardware and reinstall the drivers.
good luck
Sep 14, 2009 | Plextor PX-708A DVD±RW Burner
The plextor dvdr px 708a stopped working
Thanks for coming to FixYa, The problem you have is either a well documented software problem, corrupted plextor software or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then try re-installing the plextor software. Again if that doesn't work then your drive is most likely failed and you should replace it.
Hope this helps FixYa,
Jul 16, 2009 | Plextor PX-708A DVD±RW Burner
Formats for dvd
Actually ,, ,What kind of dvd player are you playing it back on.. ??
Did you try other players ?
does it play on the computer ?
if it doesnt then try using a slower speed or different media..
please answer the questions above so i can help you further
Dec 30, 2007 | Plextor PX-708A DVD±RW Burner
Plextor PX-708A DVD±RW Burner Logo
81 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
