Question about Toshiba SD-KV550
Dvd dosen't work
Will not advance
The screem dosen,t work
You may try: turn off the brake cable detection of your Car DVD player in setting;check your screen;check power supply of screen
Jul 17, 2012 | Pioneer AVIC-N2 Car DVD Player
We have a DVD stuck in our Phillips DVD/hard disc recorder, after loading the dvd it would not read it then we could not open the door
Dear helen, I don know if this is possible with your machine but I have removed dvds by either; turning the power off to the machine then turning it back on then trying the remote again or the facia control. I f that dosen't work try unplugging it and using a knife to gently prise the door open then manualy pulling the cradle out. I have done this also without any damage.
Oct 09, 2011 | Televison & Video
My Samsung BDC6900XXA 3D BLUE RAY PLAYER DOSEN'T WORK, IT WAS WORKING GREAT THEN MY INTERNET WAS INTERRUPTED FOR 1 DAY THEN THE INTERNET WAS CONNECTED AND NOW THE BLUE RAY PLAYER TURNS ON BUT...
I have seen this happen before when an update went bad right in the middle of an Internet outage. If you bought this recently, try to return it for a replacement. Otherwise, you will have to contact Samsung's support line to see if there is a Factory hard reset.
Aug 25, 2011 | Samsung BDC6900 3D Bluray Disc Player
How to full screen video .????
I'm not sure exactly what you mean. If you're talking about a DVD in a DVD Player, then it's possible two ways: You can (not all DVD players can do this) go into your settings and change the view to "16:9 Wide" and it works on MOST widescreen DVD videos. If not, you can zoom in your DVD picture (you will miss pieces of the screen from all four sides, but it works). HOWEVER, if you're talking about VHS tapes, it is impossible unless you convert them to DVD and then do the above. I don't work with Blu-Ray discs, so I would have no idea what to do with those. Sorry if this dosen't help!
Aug 05, 2011 | Toys
Drum rotates, timer dosen't advance, no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 12, 2011 | Kenmore 500 6952 Dryer
The dvd player on my LG E 500 (PC) dosen`t work every time i will....
you can try re-installing it....un-install it first in your device manager....
Dec 03, 2009 | Computers & Internet
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Lite -on dvd ldw 411s
If it is within the warranty send for replacement.
If no warranty exist remove DVD drive check for any noise by shaking, open item any item is loose place it back
Jun 22, 2008 | Lite On (ldw-411s retail) DVD±RW...
The Busy Light is always on
I have a couple of questions: 1) dow does this drive connect (USB)? and 2) Did it ever work? Most probably if the answer to question 1 yes and 2 no, I would say the drive is defective and return it.
Sep 24, 2006 | ASUS (DRW1608PWHT) DVD±RW Dual Layer...
Toshiba SD-KV550 Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
