Question about OKI Office Equipment & Supplies
Fatal error 43 on b430 - OKI Office Equipment & Supplies
My machine shows F:43 . What is the problem?
try to run test program if it won't help - service. F:43 is a fatal error. it could be short-circuit rotor broken engine etc...
it won't dissapear on it's own.
Oct 20, 2015 | Washing Machines
Know howmanystitches my brother bartack model has lk-b430-2
Go on the Brother web page, search for manuals with your model and serial numbers and download a manual.
Nov 15, 2014 | Sewing Machines
Oki b430 error timeout
It is a timeout value which works only when a job
with a specified size is received.
Apr 24, 2014 | Oki Electric Industry Office Equipment &...
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Binatone b430 gives message "recover
I have the same problem.
My Binatone B430 shows LOGO screen or 10-15seconds and
then it gives blue screen saying "RECOVER THE HIVE PARTITION..."
I don't know what to do, any ideas guys?
Aug 18, 2011 | GPS
Need fly b430 mobile unlock code
plz enter code on fly b430 1122 this code for for fly b430
Jun 03, 2010 | Nokia N70 Cellular Phone
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
41 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
