Question about Boating
Wire on depth finder has been piched, can tou
Wire on depth finder has been pinched, can you splice this back together. and it still work. thanks darrell
    Problem Solver:
  • 18 Answers
Yes, you can. I have done it several times. Keep the separated wires fairly short. You can pick the braided (shield) wire apart with a pin or such.
Posted on Jun 18, 2009
Schlge eltronic lever handset broken wire connector
First thing you will want to do is check the warranty for your lockset. If they will cover the lock under some part of the warranty then do that, if not. You could try getting a **** splice gauged for the wire and try splicing it together like that but there is no guarantee that it will work. Most electronic locksets have very sensitive wiring in them and even the smallest pinch on the wire can ruin the lockset. Try cutting out the parts that were broken off and splicing them together.
Feb 27, 2013 | Kwikset 909 909-15 Satin Nickel Smart...
Broke wire connector
First thing you will want to do is check the warranty for your lockset. If they will cover the lock under some part of the warranty then do that, if not. You could try getting a butt splice gauged for the wire and try splicing it together like that but there is no guarantee that it will work. Most electronic locksets have very sensitive wiring in them and even the smallest pinch on the wire can ruin the lockset. Try cutting out the parts that were broken off and splicing them together.
Feb 27, 2013 | Schlage Locks & Locksmithing
Can a cable on a depth finder be spliced
it can but will not work like a new one . . .they don't cost that much why splice it back
Feb 16, 2013 | Boating
No power going to door. Windows & locks don't work.
There is a rubber boot between the door and the body of the jeep. Pull this rubber boot back and check for a wire that has been pinched into. Mine was the thick black wire. Splice it together with electrical tape and **** connector. Worked like a charm. This is a common Jeep problem.
Mar 13, 2011 | 2004 Jeep Grand Cherokee
2004 jeep grand cherokee all electronics on driver door stopped working
I had this problem, Open the door, there is a rubber boot in the door jamb, pull the boot back, to expose the wires, on mine the big thick black wire had gotten caught in the door and pinched into. Splice the wire together with a **** connector and black electrical tape put the boot back in place should solve the problem. Also you might want to check your fuses. But the above solution is very common on the cherokee.
Mar 05, 2011 | 2004 Jeep Grand Cherokee
On the driver side door control panel windows,door locks,and mirrior stop working.
There is a rubber boot located between the door and the body of the jeep. Pull this boot back and check for wires that have been pinched into. Mine was the thick black wire. Splice it back together with **** connector and black electrical tape. Worked like a charm. This is a common Jeep problem.
Feb 25, 2011 | 2004 Jeep Grand Cherokee
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
96 cavalier starts but dies right away
Sounds as though you may have done some serious damage to your wring harness,try splicing the wires you cut back together if you know which is which. This may solve it or you may need a new wiring harness, tou may be able to find one from a salvage yard. Good Luck To You
Jul 08, 2009 | 1996 Chevrolet Cavalier
Power lock and dome light does not come on when door is opened.
I had the same problem with my 2005 dodge ram 3500 and found the wires were being pinched that run through the rubber boot on my right rear door. I had this fixed by dodge but there splice didn't last, so I took some 16ga wire and spliced it into the wire that operates the power door lock on that side and it fixed the problem. Dodge service shop did a sad job of splicing the wires back together by twisting the wires together and tape and wire broke.
Feb 21, 2009 | 2004 Dodge Ram 1500
Boating Logo
143 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
