How many ounces in .88 lbs
How many ounces in .88lbs
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
14.08 ounces in .88 lb
Posted on Apr 15, 2014
Some bags are by pounds some by cubic ft. Need to know how many cu ft = 40 lbs
1 pound =16 ounces= .0167 cubic feet
40 lbs =640 ounces = 0668 cubic feet
Feb 27, 2016 | Cars & Trucks
2004 ultra classic torque spec's on front and rear axle nuts and front and rear rotors with front dual rotors
Tighten the rear axle nut to 60-65 ft.-lb. (81-88 N•m).
Front axle nut
FXST, FLSTC, FLSTF,
FXSTB and FXSTD 50-55ft/lbs - 68-75 NM
FLSTS and FXSTS 60-65ft/lbs- 81-88 NM
Brake disc bolts
Front wheel 16-24 ft/lbs- 22-32nm
Rear wheel 30-45 ft/lbs- 41-61nm
Aug 11, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
With a typical line set, how much R-22 should a ckl30-1 2.5 ton a/c need?
the refrigeranterant charge is stamped on the unit data plate in ounces of freon. take this number and multiply it by 16 and get the pounds and the decimal point will need to be converted back to ounces. example 138 ounces equals 8.625 lbs of freon which is about 8 lbs and 8 0r 9 ounces. this is for a 15 foot lineset. measure your lineset and substract 15 , then take this number and add .6 per foot. .6 ounces of freon per foot of refrigerant line over 15 feet. you will have to use a quality digital scale to weigh in this total charge
May 23, 2014 | Goodman CKL30AR30 Air Conditioner
.25 lbs is how many ounces
.25 English pounds is 4 English ounces. .25 troy pounds is 3 troy ounces.
Apr 18, 2014 | Office Equipment & Supplies
REPLACING HEADGASKETS & NEED TORQUE SPECS. & SQUENCE ON 3.3 L 93 AWD DODGE CARVAN?
In the sequence shown in diagram using new head bolts.
First - All to 61 Nm (45 ft. lbs.)
Second - All to 88 Nm (65 ft. lbs.)
Third - All (again) to 88 Nm (65 ft. lbs.)
Fourth + 1/4 turn Do not use a torque wrench for this step.
For the valve cover gasket bolts tighten to 100 in. lbs
Oct 19, 2013 | 1993 Dodge Caravan
What is 26 ounces times two?
its 52 ounces or 3 lbs 4 ounces,
Jan 15, 2012 | Electronics - Others
I'm putting my 308 together and was just wanting the torque settings for each bolt
ok here is your list
cam shaft 66-88 ft lbs
connecting rods 36 ft lbs
damper pulley 66-88 ft lbs
head bolts 65-75 ft lbs exhaust manifold 26 ft lbs
fly wheel 45-59 ft lbs
intake manifold 25 ft lbs
knock sensor 14 ft lbs
oil pan 6-9 ft lbs
rocker arms/valve cover 8 ft lbs
water pump 15-22 ft lbs
hope this helps you
good luck
bob
May 05, 2011 | GMC S-15 Cars & Trucks
Can my Robinair 34700Z be set to recharge in ounces instead of pounds or pounds/ounces (EX. 2.4 lbs.)?
You can not use any Robinair machine in ounces to recharge refrigerant instead of LBS or KG. the software is not programed for count refrigerant in ounces!
Hope you get your answer
Dec 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
2001 chrysler voyager just replaced head what are the torque specs for head intake and pivot arm
for the head
Step 1: Bolts 1 - 8 to 61 N·m (45 ft. lbs.)
† Step 2: Bolts 1 - 8 to 88 N·m (65 ft. lbs.)
† Step 3: Bolts 1 - 8 (again) to 88 N·m (65 ft. lbs.)
† Step 4: Bolts 1 - 8 turn an additional 1/4 Turn.
(Do not use a torque wrench for this step.)
NOTE: Bolt torque after 1/4 turn should be over 122
N·m (90 ft. lbs.). If not, replace the bolt.
Intake Manifold
Bolts . . . . . . . . . . . . . . . . . . . .23 N·m (200 in. lbs.)
Intake Manifold Gasket Retaining
Screws . . . . . . . . . . . . . . . . . .12 N·m (105 in. lbs.)
Intake Manifold Plenum
Bolts . . . . . . . . . . . . . . . . . . . .28 N·m (250 in. lbs.)
the pivot arm ? whats that
Nov 13, 2010 | 2001 Chrysler Voyager
21 people viewed this question
jasbo
jasbo
