Question about Craftsman 4 Cycle Blower/Vac
Oil incarb oil in carb.
Have 67 silver shadow stored for 7 years what should be done prior to attempting staring besides clean oil clean fuel
Put oil in the carbs. SU carbs correct? Those black things on the top of the carb towers unscrew. You add lightweight oil (Volvo recommends "sewing machine" oil, motor oil will do. This creates a slightly richer mixture when starting out, thus smoother low end acceleration. Invention of Sir Henry Royce himself.
Jul 09, 2014 | 1967 Rolls Royce Silver
Help! carburetor pulse oiler on homelite xl chainsaw ut-10694-a
there is a breather hole somewhere you need to clean it up so you can find it probly on the cap
Mar 29, 2014 | Garden
Will only start by 2 or 3 drops of gas incarb
Sounds like you have trash or water in your fuel
Oct 22, 2013 | Garden
Mower starts good but only runs 5 minutes befor stalling out and won't start again until cool. It idles OK when blade is NOT engaged. Cause? And how do you set the carb adjustment screws to max. p
No adjustment for carb on newer mowers. All mowers now have a low oil cutoff. Ensure oil is full. 30w oil. If any grey is observed vin oil drain all oil. Moisture in oil. Dump old oil out every 2 yrs and refill. Ensure spark pluf is clean and gapped correctly. Ensure air filter is clean. Replace spark plug and air filter each year. Always use Stabile in gas. Spray outside of carb with carb cleaner to ensure proper choke movement.
Sep 24, 2012 | Toro Garden
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
Oil squirting into carb
No. Pull the pcv lines apart and remove any restrictions or garbage that might be in them. The end of the line that goes toward the back of the motor MUST BE VENTED TO ATMOSPHERE - you should be able to blow through it without any restriction.
Jun 29, 2010 | 2002 Buell Blast
Started my 03 blast and looked like oil and gas leaking from carb help please
no, The reason being your having some oil in your intake and carb is 1 of 2 reasons, Your Manifold Carb Coupler (Rubber Boot) is loose and your getting to much air in so its sucking it from the cylinder, thats where your getting some oil, and its probably back firing, the other reason is make sure ALL your rubber hoses and fittings are SECURLY FASTENED, if any of them are just a little loose, that will cause your carb vac to grab some oil from the cylinder too! Hope this helps!
Oct 10, 2009 | 2003 Buell Blast
Gas in the oil
what engine are you talking about ?
sounds like the floats are stuck in the carb and have flooded the engine, strip and clean the carb (s) out, change the oil and then try to restart bike.
Jun 21, 2009 | 1982 Honda GL 1100 Innerstate Gold Wing
Craftsman Weedeater won't start
You are definitely on the right track. There is only one thing that could be wrong as long as you replaced the needle valve, screen, gasket, & diaphragm. When cleaning the carb., you need to clean the small portals incarb. with a Den Tek Brush, (used for cleaning between teeth), they work great for this job. These portals, if blocked slightly, can cause this problem.
Jim
Jun 01, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 4 Cycle Blower/Vac Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
