Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Will not Start
Husqvarna YTH2448
Mowed this morning with no issues, turned it off to bag the grass, went to start it and nothing but a type of grinding noise coming from the solenoid. Checked the battery, good charge, did a volt test from the battery to the soleniod with the key turned on with good results, with key still on did the test from the starter side of the soleniod with the key on and no voltage at all going to the starter. Is this a bad soleniod or bad starter. It is not the usual cliking noise you would hear if you had a bad battery, it is coming from the solenoid itself.
  • 376 Answers
There won't be any voltage going to the starter until the key is turned to 'start' with the brake locked down. And to check that, you need to disconnect the wire to the starter. I would first check the current going to the solenoid when the switch is turned to start by disconnecting the insulated wire going to the bottom of the solenoid and hooking a test light or voltmeter to it and turn key to start. Again the clutch/brake pedal has to be held/locked down. If there is power going to the solenoid but not to the starter, it's a bad solenoid. Hope I've explained this so you can understand. Dwain
Posted on Jun 15, 2009
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Does husqvarna have a gas shut off valve
Sorry there is no fuel shut off tap on these mowers, if the same fuel has been in it for some time, i would drain it and refill with fresh fuel.
Mar 04, 2012 | Garden
I have a John Deere L110 that won't start. Mowed grass then parked it and it wouldnt start. These are all of the things we have done: New spark plug, solinoid, all 3 safety switches, battery terminals...
problem could be: brake pedal is not depressed; PTO is engaged; battery terminals are corroded; battery not charged; blown fuse; or fusible link in starting circuit is blown.These are the Most Common Causes for your Problem. Recheck your voltage of the battery and then check it under a load....Take a Jumper Cable Set and Attach the Positive Lead to the Positive Post of the Battery. Take the Other End and FIRMLY Touch the Large Post of the Soleniod on the Starter Side. If the Starter Turns the Engine, then Check the Voltage from the Ignition Switch to the Soleniod. If the Voltage is Going From the Switch to the Soleniod When the Ignition Switch is in the Start Position, then Replace the Soleniod. If No Current from the Ignition Switch to the Small Post on the Soleniod, then The Ignition Switch is Bad ....Hope this helps
May 07, 2011 | Husqvarna Viking 1
Deck will not shed the grass . the grass has to be cleaned after each mowing, lawn is not mowed when wet,
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Apr 04, 2010 | Husqvarna Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
623 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
