Question about Roland DR880
2 of the 3 display screen lights have gone out . Is this something I can repair myself
2Display screen lights have gone out . Can I repair this myself
I have an acer aspire 3000 I logged off last night and today went to turn it on it powers up but it won't display anything just a black screen
I think your OS might have gone..... So try installing an OS CD in it and see if it displays something or not. If not then your display is gone. You have to repair it in a repairing shop.
Jun 09, 2013 | Computers & Internet
The display has suddenly gone blank. It plays fine but there is no display on the screen anymore. Where can I send it to be repaired or is it something I can repair myself?
IT IS BETTER TO GIVE ITS OWN COMPANY OR GIVE IT TO YOUR DEALER ITS PROBLEM IS IHE COMPLAINTOF DISPLAY IC YOU DIDNT TRY TO REPAIR IT THANK YOU
Oct 02, 2011 | Kenwood KDC-W808 CD Player
Can an Alfa 166 ICS Display screen wihich has gone blank (Does not light up) but still functions , be repaired
http://www.ebay.co.uk/itm/ALFA-166-ICS-display-radio-sat-nav-navi-/160617155090
juat in case here you can find one to replace ..
BUT >>>>I thisnk it can be fixable ...you will have to check exactly what is wrong ..the connection or the bulb (the light of the lcd, yes it has a bulb ..I was surprised myself ) or ..if anything else is not working on the panel ...like the lighter it may be a cable or a fuse ..
In worse case is the inverter from the lcd..and you will have to look for one ..or see if you find a second hand lcd or so ...cause new ones it seams to came only with the whole unit ...
Jul 13, 2011 | Cameras
The display goes white to red to black, after a few seconds
U remove the base yet?Check all screws,remove every screws small or large.Will get this ****** open.I diagnoise ur tv problems,the LCD inverter board is dead.This board help to get LCD backlight to light to get light to the LCD screen make the Tuner board to get signal to get the picture throught to the LCD screen.This LCD inverter board is long shape board.Replaced this board u will get the backlight to the LCD screen,back and get a picture.The Websites like Shopjimmy.com,Ebay.com.U can able to buy a reburbish LCD inverter board for the replacement.
Apr 26, 2010 | Polaroid TLX-01511C LCD TV
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
The screen has gone black. Any suggestions?
Hello. With the camera on, look at the screen under bright light or sun light coming through a window. If you turn the screen just right you may see the display. If this is the case the backlite which lights the screen is burned out or has come unpluged. Most likely gone out.Most repairs are close to the cost of a different camera. One option is to look for repair sites or videos online then buy a parts camera on ebay and try it yourself.
Builderdale
Feb 26, 2010 | General Electric A950 Digital Camera
A display problemin P910i
MAn I m having d same problem....
how u make the screen work
please tell me
mail me at
chander.sharma007@gmail.com
9463126256
Jun 19, 2009 | Sony Ericsson P910i Smartphone
Broken Screen
The black liquid means the display is damaged beyond repair. That's the liquid crystal (LC) in the display (LCD). Where you send it for repairs would depend on the manufacturer, the store you bought it from, and if you have a service plan or not, but it's not something you can do yourself unfortunately. Been there too :(
Here's the link to the repair information page on the Palm website:
http://www.palm.com/us/support/contact/repair.html
Let us know how you make out.
Nov 13, 2007 | Palm Tungsten E2 Handheld
Line on screen
check ur lcd first.f same result change 2display filter near the clock battery
Sep 08, 2007 | Nokia N70 Cellular Phone
Roland DR880 Logo
Top Roland Cameras Experts
Are you a Roland Camera Expert? Answer questions, earn points and help others
