Question about Pentair Great White Part GW9508 - Vacuum Skirt
Cleaner not moving well
Cleaner will barely move nothing is blocking hose or vacuum suction seems good vacuum is about 3-4 years old
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
I have a Samsung 4320 vacuum cleaner which has started making a loud blowing noise as if the hose is split. I can't find a split in the hose and it isn't blocked. Also it isn't picking up very well. ...
Most vacuums have an air duct on the hose to adjust the amount of suction. If this becomes opened, you will hear the sound you've described and the suction will lessen. Check the wand and the hose and see if you notice a sliding piece that can be moved to enlarge or decrease an opening in the wand or hose. Use this to close the opening and your machine should work as it's supposed to.
Hope this helps and good luck!
Mar 07, 2011 | Samsung Easy 1300 Lightweight Compact...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Suction has diminished since I purchased it a year ago. Hose is not blocked, Cannister is empty, and plastic filter above cannister is clean. What could be the problem?
Three possibilities I can think of:
1. Leak/holes in the hose.
2. The fan blade are worn down or broken. The more they're worn down, the less suction.
3. The motor itself is dirty and/or wearing out.
Any one of those problem would call for a replacement of the part involved, or the vacuum itself. It could also be a combination of any of them.
Dec 14, 2010 | Bissell Versus Bare Floor Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Loss of suction
There is a blockage . Check the small hose under the sole plate
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC05 Dyson suction has stopped...there are no blockages, the seals are good, there seems to be more suction coming from a yellow box which is situated at the top of the removable cannister. There is...
My Dyson had exactly the same problem. I found the problem was caused by a blockage in the hose. Take the hose out where it joins the cleaner (it will come out if you pull it downwards gently) and take the hose out of the handle by squeezing the yellow buttons on either side. I pushed a rubber alkathene pipe down and found a piece of plastic was blocking it even though at first I was sure it wasn't blocked.
Jan 11, 2009 | Dyson DC05 Cylinder Bagless Canister...
Clogged Hose
Hi, this sounds like you have something stuck quite firmly in the hose!! If you use a good sturdy stick then you should be able to move the object without any damage to the hose. Check along the outside of the hose first just incase something has pushed its way out of the hose wall.
Get back to me.........
Jan 02, 2009 | Electrolux Centralux Vacuum
Miele Revolution 600
This is a problem with the hose, and unfortunately it will require replacement of the entire assembly.
The SES-125 hoses produced in the general vicinity of late 2002 had a tendency to start building up static and kicking the motor off after a few years. The problem was rectified, and the more current hoses do not have this problem.
Head to your friendly neighborhood Miele dealer and get a new hose, and this problem will not occur again.
-R
Aug 27, 2008 | Miele Revolution 600 Bagged Canister...
Vacuum doesn't suck (boy, what a problem :D!)
First, check the suction at the end of the hose and make sure there is good pull. On some models, there is a filter tray located under the dirt cup with a washable foam filter in it that could be plugged. It is also possible that the tray could have fallen out during your move. If it is missing, the motor will run, but won't direct the suction to the cup and you won't get any suction from the hose. Note.. not all models have this tray. If the tray is missing, you shouldn't get any suction from the hose.
Jan 13, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Pentair Great White Part GW9508 - Vacuum Skirt Logo
15 people viewed this question
Top Pentair Vacuums Experts
JoeVacs
Are you a Pentair Vacuum Expert? Answer questions, earn points and help others
