Question about Patton PUH680-U Utility Heater
Can coils be replaced?
Can the coils be replaced? I have a heater and two of the coils broke.
There's water leaking from side of heater
this is 100% broken heat exchanger its the coils inside of heater that heats the water this usually happines from really old age or because your climate temperature is below freezing and broke the coils, i see it all the time in winter season, best way to prevent this is to run your heater for fifteen minutes every month and make sure pool equipment runs all day everyday when its really cold out you can start running system normaly after your outside temp is warmer. its better to get a new heater when this happines heat exchanger is hard to install for most tech's pretty much have to take whole top part of heater off and is also expensive part
Jan 27, 2011 | Pentair Minimax NT Heater
My dryer is not drying. It does tumble but there is no heat coming out. can u help?
you will need to pull it out and unplug it , then take off the back panel , you will need to find out if it is the heater or the thermostats,, the heater you can look at and if you see the coils broke into just replace the heater
Jan 19, 2011 | Kenmore 600 6965 Electric Dryer
My heating coil is broke were is it located i have a 1991 coupdev
I don't have a manual but they are usually under the dash on the right side,,,,,look under hood for heater hoses going into the firewall that will be the heater core
Jul 07, 2010 | 1991 Cadillac DeVille
I have a 2001 chevy 5.3 engine running hot change thermstat,had to bypass heater coil because line broke off
have you started truck and seen if there is flow in the radiator? If not replace the waterpump, Although it may not leak it can still be bad....
Jun 14, 2010 | 2001 Chevrolet Silverado
Heater core hose bibb broke off at fire wall in
If the copper/metal hose broke free from the heater core, the heater core will need to be removed and replaced. let me know what size engine and I can send you the removal procedures. Big job!!
Mar 05, 2010 | 2000 Chevrolet Silverado
Will notdo anything power light is on reddy heater 55000 btu torpedo heater
Remove the top shell of the unit, see if the glow coil
tries to light up, if it doesnt you either have a bad outlet connection or the glow coil is broke
Feb 14, 2010 | Reddy R155D Utility Heater
HELP WITH MAYTAG DRYER DE712 DRYER HAD NOT BEEN USED FOR WEEK NOTICED THE TUB WAS HOT AS IF HAD BEEN IN USE FOUND A HEATER COIL BROKE AND AM REPLACING HEATER BUT DO I NEED TO REPLACE SELECTOR ALSO...
Hi, The element broke and shorted out against the metal on the dryer. The thermostat did not cause the element to break and will still be ok. You replace the element and you should be ok.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 05, 2009 | Dryers
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drying is not heating up.
try replacing thermal fuse. its cheaper than the heater element. this fuse blows when there is restricted air flow over the heating element. meaning clogged vent. you can ohm out this fuse. fuse is located at top left of heater duct with two wire leads going towards it. if its ok then remove heating element and look at coils. usually you can see one broke
Jun 24, 2009 | KitchenAid KGYS850LT Gas Dryer
Running but No Heat
Theres other things that cause a NO heat problem ... ITs wealth worth the investment of a muti meter to do checks 12.oo dollars or so...
but the heater is in the back.. need to pulll off back panel of dryer.... heater is in right corner faceing back of dryer.
here is a link to help replace... I would check to see if any coils are broke .. sometimes light taping on heater coils is required to find a broken coil
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Oct 29, 2007 | Whirlpool LER8648P Electric Dryer
Patton PUH680-U Utility Heater Logo
44 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
