Question about Brookstone iConvert iPad-Compatible Scanner Dock
Doesn' get the image scanned
It gives me an error and don't get the image scanned...
Everytime i scan a document on my lexmark all in one it doesn't come up as a letter in order for me to edit it for my changes.
When you scan a document, basically all you're doing is taking a picture of it. You end up with an image file that you can view, but not a text file that you can edit. You need an optical character recognition (OCR) program to convert the scanned image into text.
The CD that comes with an all-in-one printer or standalone scanner almost always includes some OCR software. You didn't give a model number so I can't look it up on Lexmark's site to see what downloads are available, but you can check for yourself if you don't have the disc. OCR capability is also available if you have Microsoft Office installed, and you can find under "Microsoft Office Tools". Several free OCR applications are also available on the Web.
OCR programs aren't 100% accurate. The don't always get it right, so expect to have to do some correcting in the text file that's created. Some fonts, sizes and page layouts confuse the software, and some programs are better than others. But in any case, it's better than having to type the entire document in by hand.
Jul 20, 2011 | Office Equipment & Supplies
My SerifDrawPlus X3 reboots unexpectedly after I apply image effects to an image...reads "program closing windows 7 is trying to find solution to this problem" - can you help?
This could mean your PC overheated, had a error or another problem causing Windows to force it to shut down. Is the fan in your PC working right? If it isn't working (correctly), buy a new one. If you don't know how, here's a good guide how to. If it is working correctly, a error might caused it. If so, Windows 7 will find a solution for it. Check the white flag next to the internet and volume icons. If these to are not the case, your PC might doesn't have enough memory to hold image effects and too less RAM (Memory) could cause a unexpected shutdown. Don't hesitate to ask me more! Thanks for using FixYa, and have a great day.
Jun 04, 2011 | Computers & Internet
Scanner error code
This generally indicates a driver error.
Download and run the Scan Diagnostic utility
  1. Download the HP Scan Diagnostic utility .
  2. When prompted, select Open or Run to start the download and run the installer, and then follow the on-screen instructions.
  3. Try the scan again.
The Scan Diagnostic utility checks the physical connection between the device and the computer and address the issues with the following components of the scanning software:
  • PML (Printer Management Language)
  • Yellow DOT4 entries
  • Scan Folder
  • Registry Mismatch
  • HP Digital Imaging Monitor
  • Multiple HP Digital Imaging Monitors
If an error condition is identified with any of these items, a red X ( ) appears next to the item. If there is no error condition, a green check mark ( ) is displayed next to the item. The utility is equipped with a Fix button to correct the error conditions.
Run the Unexpected Internal Error and Communications Failure patch
  1. Download the patch for HP Image zone/photo, imaging unexpected internal error and communications failure.
  2. Double-click the patch to install it on the computer.
Try scanning without HP Imaging software
Try to scan with the built-in feature of Windows operating system called Windows Image Acquisition (WIA). To perform a WIA scan, follow these steps.
  1. Make sure the product is turned on.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon for the product.
    • If there is not an icon for the product, click here to uninstall and reinstall the software .
    • If there is an icon for the product, click the icon, and then follow the on-screen instructions to scan images or documents to the computer.
Sep 21, 2009 | HP J3680 Officejet All In One Printer
Brother MFC 8460N error cc3-003-00031c0e
1.Uninstall all of MFL Pro
2.Delete HKEY_CURRENT_USER\Software\Brother\ControlCenter
3.Delete HKEY_LOCAL_MACHINE\SOFTWARE\brother\ControlCenter 4.Reinstall MFL Pro
Aug 02, 2009 | Office Equipment & Supplies
Scanner error on PC says "cannot properly communicate with scanner. Make sure the scanner is on, properly connected and properly set up to scan." the test scan works and i can see the image. the printer...
Try and open MS Word and import a picture into a document via scan, follow the prompts in Word and it should work fine. If you don,t have MS Word you can download a completely compatible application at Open Office.org. It also has the same functionality is free and allows you to save documents as .doc, .xls, etc. Sometimes a scanner requires additional software or drivers in addition to functioning as a printer. I have found scanning internal to an application a workaround or test for the scanner. If this works I would review the installation or contact the manufacturer or website. Or post and we can give it another try.
Jun 04, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Hi, I have a problem while scanning. I have Samsung SCX-4521F. Wizard gives me only to the point where I can get scanned images - one by one. Doses not give me an option to scan several pages at the same...
I believe these features have to be enabled in the administrative console with keys. There is a known issue on these printers where if it is shut down it restores the system defaults. If it was working then stopped, these features may have to be re-enabled by the printer distributor.
Aug 22, 2008 | Samsung Office Equipment & Supplies
Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Oct 15, 2007 | Fujitsu fi-5120C
Brookstone iConvert iPad-Compatible Scanner Dock Logo
16 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Tom Chichester
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
