Question about Open Mesh Outdoor Enclosure OD-OM1P
Om1p factory reset
Password
Forgot password on ICRAIG model cmp801 windows 10 tablet.
You can use a installation media to perform a factory reset:
http://www.makeuseof.com/tag/4-ways-reset-windows-10-reinstall-scratch/
If you lost just the local account password, there are many ways to reset it:
http://www.top-password.com/knowledge/reset-windows-10-password-without-reset-disk.html
I recommend you backup personal files and software licenses before doing a factory reset.
Mar 05, 2017 | Cell Phones
How can I reset my I'd username and password?
If admin page allow to create another user account, go ahead to add a new user with known password.
Otherwise, reset to factory default is the only way to remove the password (reset the password).
Be sure to back your configurations before doing factory reset because factory reset will erase everything you have set.
Oct 01, 2014 | Computers & Internet
Om1p reset
there is a reset switch hole at the bottom of open mesh router just push with toothpick and hold for 30 second the all lights goose off now the router on reset mood release the reset switch wait for re boot now its reset as factory shipped.
Jul 22, 2014 | Open Mesh Wireless Mesh Router Plug And...
I dont have the password for my hp laptop, how do i factory reset without password?
To reset password for your hp laptop you can try bootable HP System Recovery Disc to do factory reset without password. If you don't have system recovery disc then you can use Stellar Phoenix password recovery software to reset password. Once you are able to login with new password then you can easily factory reset your laptop.
Nov 02, 2012 | Computers & Internet
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Resetting router password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Aug 11, 2010 | ASUS WL-500gP V2 Router
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Forgot the password of my belkin router
Hold the Reset Button in, (You have to use a Pen Tip) for at least 5 seconds, that should reset router back to factory defaults.
Sep 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Need a password for factory reset
you are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
Jun 01, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Open Mesh Outdoor Enclosure OD-OM1P Logo
368 people viewed this question
Top Open Mesh Computers & Internet Experts
David Payne
David Payne
Are you an Open Mesh Computer and Internet Expert? Answer questions, earn points and help others
