Question about GE Dishwasher Keypad - WD34X11228
Replace KEYPAD WD34X11228
Doesn't shut off, stays only in one cycle
My GE dishwasher will not change cycles when pressing the normal wash cycle button. The lights are all on, but I cannot change the cycle from light wash to normal wash. Any ideas? Can it be reset?
Most likely the keypad will have to be replaced. If the lights change, but the cycle stays on light, it's in the control module or the switch.
Have you tried cutting the power to the unit and re-powering? If it's connected to an always on circuit, shut off the fuse that controls it and turn it back on in a minute.
Jul 11, 2015 | GE Dishwashers
Precor elliptical stuck key, display won't stay on, cycles on and off every 5 seconds, but won't continue
If you have a stuck key error, you need to replace the keypad. It will not work otherwise.
Jan 22, 2014 | Precor EFX 546i Elliptical Version 4
Litchenaid KEMC377KSS05 says DOOR and microwave wont start
follow the next step and use the common sense: God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 03, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
Aug 02, 2012 | LG Microwave Ovens
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
Door will not stay down. goes to bottom then cycles up. disconnected bell wire from wall controller problem repeated using wireless remote.. the sensors at bottom of rails one is green other is yellow,
Color of sensors doesn't matter. If your door is hitting the floor and then reversing it is traveling too far in the down direction. Locate the 'down limit' control on the side of the motor unit and turn this control a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
Jun 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
The rince light stays on and it wont run, you cant get to any other cycle
hi there,
sounds like you may have a stuck key on the keypad. disconnect the power and check the keys on the keypad as well as the pin connector behind the keypad that plugs into the board behind it for any dislogged or bent pins. replug all connections and plug the unit back into the wall. this should fix the problem. if the problem persists, replace the keypad. i know what you are thinking, new unit right?
Nov 06, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
GE Dishwasher Keypad - WD34X11228 Logo
22 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
