Question about Husqvarna Viking 1
Low gear does not disengage
Model 6430 the low gear will not disengage when trying to return to normal gear. It was last used in low gear and then stored for a few months. Would appreciate any suggestions to rectify the problem.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Husqvarna Expert
  • 300 Answers
Push and pull the speed reducer a whole bunch of times, it is stuck.
Posted on May 14, 2014
2 Suggested Answers
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
How do I Move the flywheel Elna 334
Usually you simply grasp the wheel and turn it. Most machines use the wheel to thread bobbins, and typically you pull the wheel out, directly outward away from the machine, slightly, to disengage the gears so the bobbin will wind without the needle going up/down. If it's pulled out, it will just spin when you try to turn it and the needle won't move.
If that's what's happening try pushing the wheel in, toward the machine. You can't push too hard, really, it will either pop in or not. If not, and if it won't move, it may be seized, which means one more of the gears inside have stuck together from overheating of lack of oil. If so, it's going to need a repair man.
Hope it's just disengaged.
Oct 09, 2014 | Sewing Machines
Low gear
In that old a machine I suspect the grease and oil of the mechanism has gotten hard (waxy) and is causing the gear mechanism to stick. Most likely it simply needs to be taken apart, the old lubricant removed, and new grease and oil added.
Mar 23, 2014 | Husqvarna Viking 1
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Jan 30, 2013 | Husqvarna Sewing Machines
I have an old swieng machine. Husqvarna model 6430 Sweden. The manual is in german. I will be more than happy to get it in english
Depending on how fast you want it, there are sites that offer downloads for $14.95 and ones that sell cd's for $10.99. Of course, if you buy the download, for instance, you can make your own cd copy or print it. I have used a site called sewingmanualsonline.com when I was in a hurry but that is up to you.
Mar 12, 2011 | Sewing Machines
Cannot snap decorative stitch cam back in
What model machine are you using? If it is one of the 2000 series machines (might be labelled 6430 or something else but starting with 6000), from memory you need to align the knobs on the front to the "dot" before you remove or insert a new cam.
Jan 13, 2011 | Husqvarna Viking 1
Jul 14, 2009 | Husqvarna Viking 1
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
52 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
