Question about Compaq (388110-001) Pentium III, 450 MHz ( 388110-001 ) OEM / Unboxed Processor Upgrade
Desktop monitop has black around the sides
Monitop has an inch of black around the sides where the screen saver should be also thw start menu in the bottom cornor is not there.
    Sergeant:
  • 270 Answers
It is usuall.nothing to fear
Posted on Jun 21, 2009
When i turn my computer on the screen is black for awile then it comes on where i can see my screen saver why does it do this
Turn the computer off.
Turn the computer on,
and keep pressing the 'F8' key until you see a "start-up" menu.
Choose "Start in Safe Mode".
Does the screen now look normal?
If so, set the "screen-resolution" to 800-by-600.
Then shutdown and restart.
Feb 09, 2015 | Dell Computers & Internet
Remove password
If you are using WINXP, right click on the open desktop. From the pull-down menu, select PROPERTIES. From the PROPERTIES window, select the SCREEN SAVER tab. Uncheck the "On resume, password protect" check box. If you are using WIN 7, go to CONTROL PANEL, then APPEARANCE and PERSONALIZATION, then PERSONALIZATION. At the bottom, select SCREEN SAVER. In the SCREEN SAVER SETTINGS window, uncheck the "On resume, password protect" check box. This will allow you to wake up from screen saver without having to use password.
Sep 02, 2014 | Gateway Computers & Internet
Screen saver comes on too soon cutting off movies
go to start menu, find the search bar and type in screen saver. If that does not work then go to control panel, Personalization or display and find screen saver. There you can adjust the time when it will kick on.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_922e75dcf0b59434
Aug 25, 2013 | Sony VAIO Computers & Internet
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
Bios password at start i get thw start screen tab
IF you have your bill of sale, a good local shop can reset the password but it will still cost you. At least you avoid the shipping and maybe it will be less than $100.
Programs that reset passwords are expensive to buy, IF you can find them.
Otherwise, yes, you have to send it back to the manufacture who will do it for around $100 plus shipping.
Aug 11, 2010 | Gateway Computers & Internet
Black on two sides of monitor
For the Start menu, I assume you're talking about the taskbar that appears on the bottom of the screen. Press the Windows button on the keyboard (usually located between the Ctrl and Alt button on the left hand side).Right-click on the Start button. Click on the Taskbar tab and check the box that says "Lock the taskbar". Your taskbar should return to your desktop.
Wallpaper (desktop image)
In XP:
Right click on a blank space anywhere on the desktop. Click on graphics properties. You should see a window with your Wallpaper previewed in the top window. Click in the Settings. There should be a setting for "Stretch". Select Stretch and your desktop should return to normal.
In Vista: Right click on a blank space on the desktop, click personalize/display settings/advanced settings Click on your graphics card if available or graphics properties. You're looking for Aspect Ratio options From here you will see a setting with 2 options
  1. Maintain aspect ratio
  2. Full screen (no border)
Depending on your graphics card, this process may differ slightly, but the setting you need is Aspect Ratio
I hope this answers your questions. Best of luck.
Greg
Jun 15, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
Monitor has black around two sides
click f12 and that is moniter setting you will figure it out from there
Jun 14, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
GET MY COMPUTER BACK TO DEMO SCREENSAVER
Click on Start/Settings/Control Panel, then select "Display", then select the "Screen Saver" tab on top. In the "Screen Saver" section, use the drop down menu to select the screen saver you want (you can click on the "Preview" button to the right to see what each screen saver looks like before applying it)
Aug 09, 2008 | Acer Computers & Internet
Computer
Security Policy is hinding screen saver tab.
Go to Start Menu
Click on "Run"
type: gpedit.msc
click OK
User configuration
- Administrative Templates
- Control Panel
- Display
Look at Hide Screen Saver tab
make sure it is set to disable.
Jun 26, 2008 | Dell Dimension 4500 PC Desktop
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Compaq (388110-001) Pentium III, 450 MHz ( 388110-001 ) OEM / Unboxed Processor Upgrade Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
