Question about Motorola Mobility Roadster Bluetooth Headset
How do I get out of FM mode?
Unable to change out of FM mode
How do I change stations from am to fm on a c class 320 2001 mercedes
find the mode button and press it
the different frequencies will come up as --am,fm 1, fm 2, fm 3, etc and from there you can select the different stations in that fm range
Dec 14, 2015 | Mercedes-Benz C-Class Cars & Trucks
I unable to login in my shtyle.fm account last 4hours
The site might be down for maintanence. If not, request a password change and it should work then.
Feb 09, 2013 | shtyle.fm
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Jan 31, 2010 | Denon Audio Players & Recorders
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
How do i find the FM frequency for a Connex CX-4300-300 CB radio?
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
Nov 10, 2009 | Connex CX-4300HP CB Radio
Radio changes modes randomly.
mode selector switch on bars is defective
Mar 18, 2009 | Harley Davidson 426290 AM/FM Radio
2005 Dodge Caravan Stereo Mode won't go to CD
i would take back to dealer and tell him it dont work, maybe he forgot to connect a wire.
Aug 12, 2008 | 2005 Dodge Caravan
Motorola Mobility Roadster Bluetooth Headset Logo
19 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
