Question about Fire Magic FireMagic Grill
The glo lighting is not working
Two of the glo lights went out
The light doesn't work and I read nightly. Can it be fixed?
Try a factory reset: To factory reset the glo: hold the power button ON for 15-20 seconds to make sure it is off. Press and HOLD the light button while turning on the Glo. That should put you into a factory reset if that will solve the problem (no guarantees but it has worked for others in the past).
Mar 31, 2015 | KOBO, INC Kobo Glo
Glow plus light will not go off and truck will not start
Pull the glo- plugs individually and test for operation. Next test the glo-plug relay for correct operation as it will put on the light without power to the glo-plugs.
Jul 30, 2013 | Fuel Injection Pressure Regulator for 2002...
Our grill will not light. When the knob is pressed in and turned to 'light' I can see a light inside, but it's like it's not catching and it won't light up. Each burner is doing this....
It sounds like your grill may have a glo plug type of ignition system if there is a light inside the grill instead of a spark to light each burner. If your grill is hard wired to the house elelctrical, it may be that a breaker is tripped and the power is not getting to the glo plug and the grill us using a battery back up to try and light the grill. The batterys do not last long, and when they get weak, the plug will glow, but not hot enough to light the grill. The other possibility is that you have a short, or some other problem, that is preventing enough voltage to reach the glo plug, the plug will glow, but not hot enough to light the grill.
Jul 03, 2011 | KitchenAid KBNU487TSS Gas All-in-One Grill...
Removed Dyna-Glo RMC 1601SS from closet, installed two new propane cylindars, igniter sparks but pilot will not light.
I also just pulled my unit down. Maybe I was lucky. At first it would not light, but I pressed the knob down for almost a minute. I then got a small flame that went out and soon I was able to light the pilot light.
Dec 14, 2010 | Heating & Cooling
I have a 3000btu dnya glo unvented gas fied room
I'm not familiar with these heaters but I assume there is button or something you push to get the pilot to light. There will be air in the pipe between where the gas comes in and the pilot light. You have to give it enough time for the gas to push this air out of the line. Hope this helps.
Mar 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Pilot light on Dyna Glo gas heater won't stay lit
Cleaned pilot light area with an air compressor. Problem solved!
Mar 02, 2009 | Dyna Glo "" Natural Gas Heater Mn200tba
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Dyna-Glo RMC-8001SS
Replace the regulator. We had three for three with the same problem.
Oct 30, 2007 | Dyna-Glo RMC-8001SS Heater
Fire Magic FireMagic Grill Logo
81 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
