Question about Venmar Kitchen Ranges
Wiring for air exchanger venmar ea 109
Venmar ea 109
2 Suggested Answers
SOURCE: my venmar air exchanger will not work. The motors
I am having the same problem with mine which is a greentek. I have looked it over from top to bottom, and can't find anything other than a reading of 0.385 ohms when I do a continuity test. I have called the company and they explained it might be a polarization problem with my outlet I checked this and the outlet is wired properly. so if you have solved this I would like to know how you fixed your?
Posted on Jan 19, 2011
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M ยท Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Change a lightbulb(won't budge) in a venmar 430 or 330 range hood
Get a new bulb and look at it, that will help as not all bulbs have the same base.
Dec 13, 2014 | Venmar Kitchen Ranges
Where can I purchase a venmar supra control 40320v-2
Not sure what this has to do with cars or trucks, but when I google the item you listed, there are many suppliers that pop up.
Dec 02, 2014 | Heating & Cooling
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
It often flashes ea or af and doesnt want to light
Before calling service technician, open following links for troubleshoot resources including common error codes, Bosch contact information, link to service manuals, and possible product manual
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Call Bosch 800-642-3111
Multiple error codes can mean PC board failure.
AF might be A9, but not sure.
EA is 'no flame ionization detected with water flow'
  1. Verify that all manual gas shut off valves are open.
  2. Check gas type.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Check three wire connections to ignition group on the lower front of the heat exchanger are secure.
  5. Check gas pressure.
  6. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod.
  7. Check that the minimum power fan speed has been adjusted to the proper value.
  8. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Aug 11, 2011 | Bosch AquaStar 2400ES-NG
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
My venmar air exchanger will not work. The motors do not run, when I switch from high to low speed I hear a click but that is it
Oct 25, 2010 | Humidifiers
WHERE CAN I GET RISO PARTS 033-19206-107/10EA 033-19273-106 /10EA 033-1967-203 /5EA O33-19214-100 /5EA 033-19274-102 / 10EA 033-19514-308 /5EA 444-30000-109 / 5EA Part No. S-2733G/ 3 EA
I am a distributor of Riso, and have recieved several requests for this. I belive it is regarding W91GDW108001.
These parts are obsolete, with no replacement.
Nov 25, 2009 | Riso Office Equipment & Supplies
Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
Sep 06, 2009 | Venmar Kitchen Ranges
Kitchen Ranges Logo
161 people viewed this question
Top Venmar Kitchen Ranges Experts
Gil Shultz
ray gallant
Dan Apthorp
Are you a Venmar Kitchen Range Expert? Answer questions, earn points and help others
