Question about Dmm Screw Extractor, #4
Extracting a screw that broke 2 extractors
I have been tryiny to extract a screw and have broken to types of extractors can you help the screws i am trying to extract on on the rotor of a 2003 acura tl
  • bozcro
    bozcro May 11, 2010
    use the biggest possible extrator you can , with the deepest hole you can drill. which and what rotor are you trying to extract ?
    Problem Solver:
  • 16 Answers
Drill as large a hole as you can down the centre of the broken screw, and use an "Easy-out" left thread screw extractor of as large asize as you can. If the rotor is out of the car, soak it in a mixture of Coke and light machine oil before trying to extract screw.
Posted on Jun 15, 2009
Stripped screw moen
Get a set of screw extractors from the tool section of a hardware store. This tool will easily extract the screw. If the threads in the handle are ruined, then you'll have to replace the faucet.
Jan 28, 2014 | Ace Hardware Ace Diverter Handle
BROKE OFF HEAD OF A BOLT HOW DO I EXTRACT IT
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 09, 2011 | 1998 Volkswagen Beetle
How do I take a stripped torx screw out of my throttle body!
Hi, The best way to remove it is to use a screw extraction tool.
Which works by you drilling a small hole in the top of the screw and then screw in the extractor which as you wind it in will start to turn the screw out.
Hope this helps.
Thanks
Jason
Jul 28, 2011 | 1995 Dodge Intrepid
Bolt broke off inside side mount battery. how do i get it out
Go to the parts store & get a bolt/screw extractor.
It works by first drilling a small hole into the bolt you broke, then you screw the extracter, counter-clockwise into the bolt & it will back it out. Soak the broken bolt with lubricant/wd40 before trying to extract. Don't drill more than the depth of the bolt.
good luck.
Feb 14, 2010 | 1992 Buick Century
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Cant get it off
First, you need to put a jack under the engine to keep it from falling while you're working on it.
Best way to remove a broken bolt (if there is enough of it sticking out) is to use vise grips. If it's broken off flush, the next approach would be an E-Z Out (screw extractor). Extracting broken screws/bolts is not an easy task especially if access is restricted.
Sounds like you may have to take it to a repair shop.
Apr 29, 2009 | Ford Taurus X Cars & Trucks
How do I remove the radio from a 1998 Honda CR-V?
UNSNAP PUSH-PIN FASTENERS FROM BOTTOM OF CENTER CONSOLE
AND REMOVE BOTTOM PANEL.
2. EXTRACT 4 SCREWS FROM BOTTOM EDGE OF BEZEL. EXTRACT 4
SCREWS FORM INSIDE DASH BELOW POCKET. PULL CUP HOLDER/
POCKET ASSEMBLY OUT OF DASH AND REMOVE.
3. OPEN GLOVE BOX AND REMOVE STOPPERS. EXTRACT 2 SCREWS
FROM RIGHT SIDE OF CENTER DASH BEZEL..
4. FROM BELOW STEERING WHEEL EXTRACT 2 SCREWS FROM BOTTOM
EDGE OR PANEL, UNSNAP UPPER EDGE OF PANEL, UNPLUG, AND
REMOVE.
5. UNSNAP TOP EDGE OR CENTER LOWER BEZEL, UNPLUG, AND REMOVE.
6. EXTRACT 2 SCREWS FROM SIDES OF POCKET.
7. UNSNAP RADIO/AC CONTROL DASH BEZEL, UNPLUG, AND REMOVE.
8. EXTRACT 2 SCREWS FROM EACH SIDE OF THE RADIO BRACKET
ASSEMBLY TO REMOVE RADIO FROM DASH/AC BEZEL.
Apr 09, 2009 | 1998 Honda CR-V
Valve cover gasket
No...not really. What you will want to do is get a tool called an easy out or screw extracter, from a place like Sears or somewhere else that sells tools. Take a screw from your valve cover so you know the size of extractor you need...it only costs a few dollars.
You have to drill a small hole in the center of your broken one. Then take the extractor and put pressure on it as you unscrew it. It should come right out. Find a replacement screw at the auto parts store or even look at Home Depot or equivelant
Mar 16, 2009 | 1995 BMW 5 Series
Collet base removal
Try using a tapered wood screw or sheet metal screw as an extractor. Choose one of a size that will let its tip go down into the broken collet and get a grip when you twist it. If that fails, you might use a screw extraction tool.
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Dmm Screw Extractor, #4 Logo
214 people viewed this question
Top Dmm Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Dmm Tool and Hardware - Other Expert? Answer questions, earn points and help others
