Question about Canon Cameras
Progress lighting p5993-50 overide
Turn off motion sensor
I have motion sensor flood lights that are not turning on. I put it on test & it does turn on. But when switched over to 1, 5 or ten minutes it won't turn on. The red light on the sensor does turn
April, you didn't mention whether you did the test at night. In addition to motion sensing, the flood light also detects darkness before allowing the bulbs to light up. If it is night, check also that some other light source is not illuminating the sensor. If so, that could fool the sensor into thinking it is daytime.
Mar 03, 2014 | Electrical Supplies
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
Motion sensor light lights up during the day
Is this new installation, or old motion sensor that has malfunctioned? Add comment.
Motion sensor has adjustment dials.
Motion sensor that lights in day has probably gone bad.
Occupancy switch and motion sensor wire the same:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Gene
h
Aug 10, 2013 | Hardware & Accessories
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I have motion lightts on my back porch. I would like to just plain turn them on when I have a back yard party, but I don't know how to over ride the motion sensor. Can you help? Thanks.
On most motion sensor lights if you turn the switch on, then off and on quickly, they will stay on till you turn them back off. Leave it off for at least 10 seconds and turn it back on to go back to the motion sensor.
Sep 06, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
Motion Light doesn't work on switch
Try turning the switch on and off and back on again this usually will bypass the motion detector. when you are finished you can turn the switch off for a few seconds and back on and it will resume its normal function
tom
Dec 11, 2008 | Electrical Supplies
Cameras Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
