Question about Rhino Electronics - Others
Constant undervoltage alarm
Even with no load applied.
In new 3-alarm system just installed by electrician the alarms issue 3 long beeps and "FIRE" about every 10 minutes. Kidde is not available to help. Can you?
I think it could be one of three things.
The electrician may not have installed the back-up batteries.
The electrician may not have turned the primary power to the detector circuit on when he completed the work and now the battery is depleted.
The electrician may have tied the the detectors into a switched circuit which does not apply constant primary voltage.
Hopefully you can contact the installer to troubleshoot his work.
Feb 13, 2016 | Kidde i12040 Hardwire Smoke Alarm with...
Constant sounds coming from my truck alarm
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Jan 03, 2014 | 5704x 570.x 2-Way Security and Remote...
Proform 480E treadmill doesn't work
Check your drive motor with a 9v battery....if it turns, your controller is likely bad, provided your wiring harness is not damaged. Call 877-805-1030 if you need on site service.
Dec 24, 2013 | Proform Exercise & Fitness
Lincoln con wont stay started new batt new alt batt dies car shuts off wtf?
The harness from the battery to the alternator may be damaged or the harness form the firewall to the alternator may be damaged. Check fusible links by applying a gentle but firm tension on them- if they pull apart, they have failed. The area to check closest for damage is anywhere the harness goes over a sharp corner.
If equipped with an aftermarket alarm, or aftermarket stereo system- disconnect the alarm for now, and verify the stereo or other radio is attached to a switched accesory wire. If they are on a constant power source wire, they will run a battery down fast. as fast as a day or even part of a day if quiescent current draw is great enough.
Jan 15, 2012 | 1996 Lincoln Continental
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Apr 04, 2010 | Electronics - Others
Constant paper jam..no paper have restarted several times
Got the same problem here! Did you find a solution?
Oct 24, 2009 | Office Equipment & Supplies
How do i disable a alarm system on a 2003 saturn L300?
The 2003 Saturn Vue is equipped with the Passlock II system
The factory alarm can be programmed on or off using the factory remote. To turn the factory alarm on or off, turn the ignition on and
press the PANIC button 8-10 times in 5 seconds. Within 3 seconds press UNLOCK to turn off the alarm or LOCK to turn on the alarm.
Sep 11, 2009 | 2003 Saturn VUE
Need a alarm clocl on it or were is it?
Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
Apr 19, 2009 | Motorola Mobility I335 Cellular Phone
UNDERVOLTAGE CONSUMER DEFECTIVE
i have the same problem with my 2001 C240 and my a/c does not work properly as a result.
Oct 31, 2008 | 2001 Mercedes-Benz C-Class
Electronics - Others Logo
Top Rhino Electronics - Others Experts
Are you a Rhino Electronics - Other Expert? Answer questions, earn points and help others
