Question about Philips Norelco 1160XCC SensoTouch 2d Electric Shaver with Jet Clean System, Black/Brown
How do I get the lock light to turn off?
The shaver will not work
Unlock Phillips shaver
I think you press and hold the switch until lock symbol turns off.
Oct 05, 2014 | Philips SmartTouch-XL HQ9190 CC Electric...
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
My shaver turns on but it immediately makes a click and stops, and then the light turns red. If I open up the top and turn it on, the three shafts turn at what seems like a normal speed. I have tried...
The heads are either damaged causing the blades to lock up or it is clogged up to the point that they can no longer turn. Inspect the outer combs for damage. If damage is visable, you will need to replacethem. You will find replacements for 7775X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If no damage is visable, take the blades out and thoroughly clean them. You can soak in rubbing alcohol to help break up any greasy build-up. Once cleaned you should be able to turn the blades inside their combs with your fingers. If any of them snag you will need to replace them
May 16, 2011 | Norelco Cool Skin 7775X Electric Shaver
Lights come on but razor does not work
Try turning on the shaver with the heads removed...you may have a damaged head that is causing the shaver to lock up. If shaver runs with heads removed, you will know this is the problem.
Problem could also be a loose connection inside or even a bad battery
parts for your model are available at shaveroutlet.com
Jan 14, 2010 | Philips Health & Beauty
The on/off mechanism on my dads braun 6520 is stuck. It won't turn on.
Hello running girl, Have you looked to see if maybe the "lock-off" feature hasn't been engaged?
If you look at the razor, right above the on/off and sideburn trimmer selector, you should see a full bar that goes all the way across the shaver. Push this up toward the shaving head to unlock the razor and the shaver should work fine again.
This is a Braun design feature there to help prevent the shaver from accidently getting turned on when packed in your luggage, etc. and running down a fully charged shaver.
There is nothing like reaching for what you thought was a charged and ready to use shaver and discovering that it got switched on and ran the batteries down.
Other than having the lock off feature engaged, I can't think of anything that would cause the switch not to turn on, unless the shaver was dropped and damaged. If that's the case, you will want to have it looked at to make sure the printed circuit board hasn't been broken, etc.
Typically this isn't something that most folks can undertake a diagnois and repair, so I'd suggest you contact www.electricshaver.com or call them at 1-888-476-1785 to get an estimate for repairing it.
Hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Flex Integral 6520 Electric Shaver
Wont turn on
Make sure the lock button is not in the lock position.
Aug 25, 2007 | Braun 360° Complete 8985 Electric Shaver
Replace heads light
I have been able to reset the replace head light on my 8894xl shaver by do the following: Step 1 - Fully charge and clean shaver Step 2 - Turn on shaver holding down on button until shaver display recycles from 0 to xxx minutes. Step 3 - Turn shaver off Step 4 - Turn on shaver again and hold down button until shaver beeps ONCE. (Light will go off)
Jun 09, 2007 | Norelco 8894 XL Electric Shaver
Philips Norelco 1160XCC SensoTouch 2d Electric Shaver with Jet Clean System, Black/Brown Logo
69 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
