Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
Changing oil in tranaxle ztrn mower 52" bobcat leo what type and weight
Oil dirty pump went down replacing internal filter want to put in right weight of oil
2 Suggested Answers
normdoty
  • 36 Answers
SOURCE: can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Posted on Jun 29, 2014
2003 Mitt Lancer Oz Rally. Oil light goes on alway under 2000 to 1500rpm. After i did a oil change
Check your sensor or take your black wire off from your battery for ten minutes then check.
Mar 20, 2016 | Cars & Trucks
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
Hello, The air filter in mypush Poulan is really dirty. HOw should I clean it? I did wash it in a very soapy soultion and it's dry now. Do I oil it before I put it back in?
Depends on the type of filter. You don't oil a paper cartridge, but you do oil a foam one. Some mowers have a foam sleeve over the paper cartridge. Oil it, then squeeze out the excess oil,
May 19, 2010 | Poulan "Poulan" Push Mower
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How many quarts of oil does it take for a 2007 toyota avalon?
If it's a 4 cylinder it holds 4 quarts ( with new filter). If it's a v-6 it holds 6 quarts (with new filter).
Jan 20, 2010 | 2007 Toyota Avalon
Oil pressure is high should I do an oil change or will that help at all?
Oil pressure is the amount of hydraulic force used to move the oil through the engine parts. High pressure can be caused by
  1. wrong type of oil, 50 weight in an engine thatshould have 5W-30,
  2. plugged part of the oil system,
  3. sludge in oil passages or very dirty oil filter,
  4. internal engine part(s) being out of tolerance,
  5. clearances too tight on bearings or oil pump, or
  6. faulty sending unit or
  7. Gauge just showing high pressure.
So the first way to check is by just changing the oil, go ahead and do it. It might fix the problem.
Nov 17, 2009 | Office Equipment & Supplies
My daughter tells me that the mechanic at a garage in town tells her that the OIL FILTER doesn't have to be changed.Is that correct???
If it has an oil filter that can be removed, then it has to be changed at least every other oil change. Better repace with every oil change. Some modern cars as some european sedans (bmw and mercedes) as well as some fancy corvettes and probably vipers, do not have external oil filters and do not even have a dipstick. On this cars, the oil is special to be changed every 30 top 50 thousand miles, but even on this vehicles, there is an internal oil filter that also has to be replaced.
Sep 25, 2009 | 2004 Mitsubishi Outlander
Changing oil filter
There may a plastic cover under the engine with four 10mm bolts, take off 3 and swing it. If you don't see a cover, follow the dipstick tube down to the bottom of the engine, the filter is right next to it, in the front of the engine next to the oil pan. It is the regular screw on type, just a little fella.
Aug 22, 2009 | 2006 Ford Escape
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
226 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
