Question about RCA D52W23 52" HDTV CRT TV
I WANT TO CONVERGE MY RCA REAR PROJECTION TV. HOW?
Is there a dvd recording to help you converge Colors Etc? Thanks Joe
  • RCA Master
  • 8,617 Answers
Here is a link to the detailed instructions for the RCA ITC222 convergence adjustment proceedure CD with detailed photos.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
Posted on Jun 15, 2009
How can you tell if the bulb is burned out on a RCA 52 inch projection
If you are missing one of the colors but still have an image (red, green or blue). Real simple, turn on the TV and see if there are any colors missing from those. Most rear projections have a color bar you can put up or a converge feature which is used for aligning the colors for a clear picture.
Aug 31, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors will not converge on my RCA SRS Focus, model D52130. When I make an attempt to automatically converge, it says to reduce the light in the room. We even covered up the screen with a blanket at...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Out of convergence - getting error that sensor is not getting any signal during auto-converge - is there a way to manually converge - or replace anything??
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | RCA D52130 52" Rear Projection Television
Will not converge
hello, the convergence ic's have gone bad in your tv . and sometimes they fail because of a 50 mfd @ 50v capacitor by each ic goes bad. if you have the skill at soldiering and desoldiering you may try repairing it yourself otherwise leave it to a qualified repairman. thanks .....techman...580-243-8025
Apr 01, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
Cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
No way to converge colors
The convergence board could have recived damage when it was shipped, or there could be a bad connection or plug came loose while transporting, or the convergence IC's may need to be replaced. All these things ,unless your a trained tech with soldering experience, will need to be checked out. Good Luck
Aug 12, 2006 | RCA P52936 52" Rear Projection Television
RCA D52W23 52" HDTV CRT TV Logo
328 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
